Local Time 04:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Powershell Date/Time Script
crackerjack
Posted: 11:59am 18 Mar 2012
Hi again one-and-all.
A small tip this time. For those who don't have hardware RTC setup and want their Maximite Date and Time updated easily, the following is a small Powershell script to do so. Just run the script from your PC when you connect the MMM/DM and Date and Time is quickly set without fiddling about (or forgetting). There are probably ways of kicking off the script as soon as the USB device is detected, but I do it manually. As for Powershell scripting, that is a whole other story I won't get into now, but for those who are interested, script follows (it could undoubtedly be done in any language of choice which has Serial IO functionality):
[code]
$port = new-Object System.IO.Ports.SerialPort com4,9600,None,8,one
$port.Open()
$port.WriteLine("date$=`"" + (get-date -format ("dd/MM/yyyy")) + "`"")
Start-Sleep -m 100
$port.WriteLine("time$=`"" + (get-date -format ("hh:mm:ss")) + "`"")
Start-Sleep -m 100
$port.WriteLine("Cls");
$port.Close()
[/code]
Note the com4 in the first line should be set to whatever COM Port your MM/DM is connected to, and that the script should be run before firing up TeraTerm (,etc.) and connecting to the *Mite.
Cheers.
CircuitGizmos
Posted: 03:46pm 18 Mar 2012
That is pretty much the same thing that my button does in MMIDE. Very convenient to set the date/time first thing.
BobD
Posted: 01:46am 19 Mar 2012
  crackerjack said   There are probably ways of kicking off the script as soon as the USB device is detected,
Does anybody know how to start this script on usb detection? I have been googling but no success so far. Edited by BobD 2012-03-20
Ray B
Posted: 09:40am 19 Mar 2012
Original solution to this challenge using TeraTerm as previously posted by James of Canberra as follows:
http://www.thebackshed.com/forum/forum_posts.asp?TID=3582
RayB from Perth WA
crackerjack
Posted: 10:33am 19 Mar 2012
Thanks RayB - nice one by James. I think that was posted just before I joined the forum. Good to see a simple solution.
Cheers.
