Local Time 04:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Last question - variable range MMBASIC
robarino
Posted: 01:26pm 15 Mar 2012
I was wondering if there is some sort of scale command where you can set the range of a variable. For instance voltage range 1 to 5.0000 to the range 1 to 300?
I have looked at the manual and cannot seem to find it.
Posted: 01:32pm 15 Mar 2012
Hi robarino
Do you mean a multiplier? If variable A ranges from 1 to 5, then A*60 ranges from 1 to 300.
Also remember the Maximite can only measure up to 3.3 volts, its supply voltage.
robarino
Posted: 01:38pm 15 Mar 2012
Hej Glenn,
Thanks for replying! I know you can multiply but in Arduino for example you can set the range before and it takes care of it for you. I forget the command but it is useful.
Posted: 05:43pm 15 Mar 2012
I wonder if the Arduino does it because it's a quite slow system. The MM & DM are so much faster that a few multiplies etc don't normally matter.
Vikingboy
Posted: 11:25pm 15 Mar 2012
I think the command at least on other basic systems is called "Map", I only know because when I first started using the maximite I read a few online BASIC guides and I saw it in one and thought it would be really handy, still do ;)
AFAIK it maps an input range to an output range linearly, would be handy for handling analogue inputs easily.
rgds,
Andrew
robarino
Posted: 08:35am 17 Mar 2012
@Vikingboy!
Exactly! It is incredibly useful!
djuqa
Posted: 08:38am 17 Mar 2012
Just create a Defined subroutine that accepts the input value and returns the desired value.
VK4MU MicroController Units
