Local Time 04:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Musical notes in MMBASIC
cosmic frog
Posted: 09:37pm 14 Mar 2012
Hello, Just finished working out all the notes for use in the SOUND Command.
E=83,F=88,F#=93,G=98,G#=104,A=110,A#=117,B=124,C=131,C#=139, D=147,D#=156.
To play the next octave just times by 2 ie.C=131*2 is 262.
So a list of notes with five octaves would look like this-
E 83,165,330,660,1320
F 88,175,350,700,1400
F# 93,185,370,740,1480
G 98,196,392,785,1570
G# 104,208,416,832,1664
A 110,220,440,880,1760
A# 117,233,467,934,1868
B 124,247,495,990,1980
C 131,262,525,1050,2100
C# 139,277,555,1110,2220
D 147,294,558,1176,2352
D# 156,311,623,1246,2492
Hopefully this list will make it a lot easier when writing music in MMBASIC.
Dave.
Raros
Posted: 12:16am 15 Mar 2012
Hi Dave
If you can help, see the CircuitGizmos site
CircuitGizmos cgmmstick1
download begmax.pdf on page 43 there are all the musical notes.
bye
Edited by Raros 2012-03-16
rodent59
Posted: 05:58am 15 Mar 2012
Hi Dave,
For the equally tempered scale, the frequency ratio of adjacent notes (one semitone) is the twelfth root of two. 2^(1/12) ~= 1.05946.
So, rather than enter note frequencies individually, they could be calculated by, for example (not tested!),
C1=32.703196 ' Frequency of C1 in Hz (Note: A4=440Hz, concert pitch)
dim freq(8,12)
for octave=1 to 8 ' octave 4 is middle C to B above it
for note=1 to 12 ' 1=C, 2=C#, 3=D,..., 12=B
freq(octave,note)=C1*(2^(octave-1))*2^((note-1)/12)
next
next
Perhaps write it as a subroutine 'PitchInit'
Rod.
CircuitGizmos
Posted: 02:42pm 15 Mar 2012
  Raros said   Hi Dave
bye
Or via this link: Music on Maximite
cosmic frog
Posted: 11:47pm 15 Mar 2012
Thanks for the info. I used a guitar tuner to get my notes, some look like they are a little off
I needed a list of notes as I'm trying to get my UBW32 to play (pseudo) polyphonic music using just one voice! So far I've got it playing a bass line and melody at the same(ish) time and the results arn't that bad, it sounds a bit like a Spectrum computer and works by quickly playing one note then the other. I'll post the results when I've done it.
Dave.
DuinoMiteMegaAn
Posted: 01:15am 16 Mar 2012
For the Maximite sound experts, here is a quick sound question.
I am using the Maximite sound output as an alert and warning indicator..
Is there a program that I can use to translate a wave file into Maximite sound commands? (wave files have a lot of useful sounds like firetruck, siren, etc.)
It is extremely hard, without a musical background, to create the needed sounds for my alerts.
Edited by DuinoMiteMegaAn 2012-03-17
crackerjack
Posted: 02:35am 16 Mar 2012
DuinoMiteMegaAn - not possible without (at least some) extra hardware. See this post for ideas on playing WAV files from a *Mite.
crackerjack
Posted: 02:13am 17 Mar 2012
For some interesting musical possibilities see this video and this one too. I'm not sure if the You Tube poster (skywodd) has ever been a member of this forum, but this is a fine effort and he has obviously spent a fair amount of time coding up not only the program, but the song files too.Edited by crackerjack 2012-03-18
cosmic frog
Posted: 02:57pm 21 Mar 2012
I've finally got round to making a Youtube video of my UBW32 playing polyphonic sound. See what you think. The tune is Magic Roundabout. UBW32 playing polyphonic sound
