Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : jpeg to bmp
teun
Posted: 03:07pm 09 Mar 2012
Hi i hope someone can/will help me. I would like to show a image for a few seconds before my program starts. So now i use a small program i found here on the forum to show a bmp 1bit picture and that works great but now i have to compress my jpeg pictue into a bmp picture. Is there a simple program to do that?
Thanks in advance.
djuqa
Posted: 08:32pm 09 Mar 2012
I use either Photostudio 6 (Commercial Software)
or use this online site
http://www.coolutils.com/online/image-converter/
That site also has a Downloadable versionEdited by djuqa 2012-03-11
VK4MU MicroController Units
teun
Posted: 09:39pm 09 Mar 2012
Ok thanks i will take a look. I see i can transfer to BMP but cannot see how to convert to 1 bit BMP?
CircuitGizmos
Posted: 09:48pm 09 Mar 2012
Try Irfanview - you can convert to pure B/W - should be 1 bit.
psergiu
Posted: 02:06pm 25 Apr 2014
Sorry to dig up such an old thread but i have a similar problem - Converting 8-colour images to Colour Maximite-compatible BMP files.
The trick is - i don't use Windows.
I created the image with GIMP (latest versions do include a Indexed 8 colour palette named "Colour Maximite")
All the BMP files saved with Gimp or Preview.app are rejected by the MaxiMite (4.4B) with "Error: Corrupt file"
I tried 4 bpp, 8 bpp, full 8 colour index, reduced colour index - same error.
Has anyone successfully created a Colour Maximite-compatible BMP image using non-windows software ?
Thanks.
Posted: 02:56pm 25 Apr 2014
The format needs to be 4 bit or 16 colour.
You could try one of the Windows programs and run it under Wine.
Try opening an image saved from the Maximite with GIMP to see what format GIMP thinks it is.
