Forum Index : Microcontroller and PC projects : Shifting numbers in MMBasic
DuinoMiteMegaAn
Posted: 03:35am 08 Mar 2012
I have 3 bytes that I am re-combining from an I2C read operation from the Bosch BMP085.
The below formula is needed to find the raw pressure. Can this be done in MMBasic?
Any help is appreciated.
ref (y = 0-3)
x = (byte1<<16 + byte2<< 8 + byte3) >> (8-y) <-------- Formula
BobD
Posted: 04:15am 08 Mar 2012
x=(byte1*(2^16) + byte2*(2^8) + byte3) \ 2^(8-y)
I had a bit of uncertainty about the 8-y. Not sure what you wanted. I assumed right shift by 8-y.Edited by BobD 2012-03-09
crackerjack
Posted: 04:19am 08 Mar 2012
In a word - yes.
I don't have the time for a full code example now, but essentially to LeftShift (<<) by 16 or 8 bytes, do this:
byte1 = (byte1 * (2 ^ 16)) And &hFFFF
byte2 = (byte2 * (2 ^ 8)) And &hFF
x = byte1 + byte2 + byte3
Then RightShift(>>) by 8-y bytes is:
x = x \ (2 ^ (8 - y))
Cheers,
crackerjack
BobD
Posted: 04:29am 08 Mar 2012
and you can toss away a lot of the parentheses as exponentiation has the highest priority in processing. I just checked the manual. So byte1*(2^16) can become byte1*2^16 and it will process correctly.
A further thought: there is a maximum number that you can process before you lose accuracy. A quote from page 8 of the reverence manual:
The range of integers (whole numbers) that can be manipulated without loss of accuracy is ±16777100
This is just short of 256*2^16 which is 0xFFFF8C. It's an odd figure. Anyway, with your calculation you could easily exceed that figure.Edited by BobD 2012-03-09
crackerjack
Posted: 04:54am 08 Mar 2012
Apologies - another pair of FF's are required on the end of the Left Shift operations in my post.
The AND'ing is not strictly necessary, but does force the truncation of any bits that may have been in, for example, byte1 if byte1 was not "byte-sized" to begin with.
crackerjack
Posted: 01:10pm 08 Mar 2012
Andy, the left shift part of your formula may be handled by the byte2num function. I've never used it, but it just occurred to me that it could do at least part of the job in terms of that formula. Let us know how you go. Cheers....
DuinoMiteMegaAn
Posted: 11:07pm 10 Mar 2012
The problem with shifting bytes to reconstruct a number from I2C buffer reads
is that the sign bit is missing? I know for a fact that the BMP085 16 bit constants
have some/few "signed" constants. How do I restore the sign?
BMP085_AC1 = (BMP085_buff(0)*2^8) + BMP085_buff(1)
BMP085_AC2 = (BMP085_buff(2)*2^8) + BMP085_buff(3)
BMP085_AC3 = (BMP085_buff(4)*2^8) + BMP085_buff(5)
BMP085_AC4 = (BMP085_buff(6)*2^8) + BMP085_buff(7)
BMP085_AC5 = (BMP085_buff(8)*2^8) + BMP085_buff(9)
BMP085_AC6 = (BMP085_buff(10)*2^8) + BMP085_buff(11)
BMP085_B1 = (BMP085_buff(12)*2^8) + BMP085_buff(13)
BMP085_B2 = (BMP085_buff(14)*2^8) + BMP085_buff(15)
BMP085_MB = (BMP085_buff(16)*2^8) + BMP085_buff(17)
BMP085_MC = (BMP085_buff(18)*2^8) + BMP085_buff(19)
BMP085_MD = (BMP085_buff(20)*2^8) + BMP085_buff(21)
BobD
Posted: 11:55pm 10 Mar 2012
don't know about this chip / sensor but some (many?) use twos complement numbers. Check out my post here on how to manage negative twos complement numbers or look in wikipedia. You would have to combine your bytes before processing as a twos complement.
Posted: 12:19am 11 Mar 2012
OMG...
My brain is sore after reading these posts...
I thought I could program in basic but now I am not so sure...
Glad there are some smarties out there for us Dummies.
Good work Lads,
Mick Edited by bigmik 2012-03-12
BobD
Posted: 12:51am 11 Mar 2012
I had a look at the datasheet for the BMP085 and while it indicated which constants are signed it did not say the method. I suspect Bosch are relying on people using their code examples to do the job. Andy, you may have bitten off a large piece to chew on.
Assuming twos complement:
read your pair of bytes, combine them into a 16 bit number as shown above, check if the number is equal or greater than 0x8000 (means it is negative), if not then treat it as positive else invert it (number XOR &HFFFF) and add 1 and then change the sign to negative.
DuinoMiteMegaAn
Posted: 01:49am 12 Mar 2012
@BobD This BMP085 temp/pressure/altitude/weather calculations in FP is probably the hardest algorithms I have encountered to date. The trouble is, I bought this complex sensor and now I have to make it work but being a hacker and I live by my hacker moto "don't give up" Can you spare a logic anaylzer for this $%#$% chip?
BTW ... thanks for your 2's complement help Edited by DuinoMiteMegaAn 2012-03-13
