Forum Index : Microcontroller and PC projects : Project: Precision Outback Dot Clock
DuinoMiteMegaAn
Posted: 02:09pm 02 Mar 2012
Project --> The Precision Outback Dot Clock
This is one special precision time piece. Perfect for those out in the bush with no PC, GPS, RF WWV signals and devices. All you need is a 5 VDC USB power source.
The clock uses the Maxim-IC +-5 ppm I2C TCXO DS3231M real time clock with a 3 V lithium battery backup (CR2032). (~ 2.5 min/yr).
Due to very special MMBasic algorithms, this clock can run for 8-10 years without human intervention even with semi-annual daylight savings time changes!
It displays civilian time with AM/PM, day of week, month, day, year, daily sunrise time, daily sunset time, ambient light, ambient humidity RH% and ambient temperature in degrees F.
The MaxiMite aka PIC32 CGMMStick1 powers the custom made multicolor, "dot" LED display and sensor board. All the GPIO signals on the CGMMStick1 were completely used up in this application.
Outback Dot Clock operation and design Q & A
Why did you use five minute intervals for this Outback Dot Clock?
There is limited GPIO on the CGMMStick MaxiMite for this application. There is only 20 GPIO and I needed ALL 20 GPIO for this Outback Dot Clock. Using five minute intervals is still a great way of telling time. You will never be late because the time is rounded up to the nearest five minute interval.
Note: If I had to indicate all the minutes, I would need, at least, 60 GPIO plus extra discrete drivers and the power current draw plus cost would increase dramatically.
How can you tell the clock small hand (hour) from the big hand (minute)?
I flash the small hand (hour) yellow LEDs at a high rate and keep the yellow LEDs on for the big hand (minutes) steady.
How can you tell the time with only 5 minute intervals?
I round up the time in 5 minute intervals. The multi-color LED pattern on the clock face makes it very easy to tell the time. The time is very precise (+- 1or 2 minutes/yr) but the readout is in 5 minute intervals. This automatic clock can run for 10 years WITHOUT setting the time, even for daylight savings time and be only 10 minutes off! It can operate in extreme temperature conditions and still be precise. That's why I called it the "Outback Dot Clock". Its made for an extreme remote location that has no PC,GPS or WWV radio signal.
How can you tell the the "pending time" changed before the hour?
Time half past the hour is shown "as is" and the time before the hour (30 minutes before the hour) - the hour hand is incremented by one hour. Time read before the hour like 5:45 PM is always read 15 minutes before 6.
What happens if both the small and large clock hands point to the same 5 minutes interval?
Showing only one hand segment means both the minute and hour hands are overlapping.
How can you tell PM from AM?
There is a separate red LED around 4 o'clock to indicate PM. (AM is off)
What is the current draw of the LEDs?
The special low power high brightness LEDs (Kingbright) "dot" draws only 1 ma. each ( ~ 36 ma. total all on)
The erase/write cycle on the PIC32 is 1000 cycles. How do you prevent exceeding this value?
All application files are stored on the CGMMStick1 SD card.
How can you display years and day of the month on the clock face?
Since the clock face shows 1 through 12 and decimal numbers are 0-9 then its only a matter of flashing a multi-sequence segment pattern on the clock face.
What are the three switches used for? (Two tac switch and one reset switch)
Each switch press will create the following LED flash sequence response:
Tac switch #1 button press ...
Day of week 1-7 Sunday = 1
Month 1-12
Day of month 1-31
Year 0-99
Tac switch #2 button press ...
Temperature (ambient) degrees F.
Humidity (RH%) 0-100%
Light (ambient) 0-10 <------ 0-10 intensity 0=dark 1-10 light
Reset switch #3 press...
On power on reset, program restart or reset switch closure will restart the Outback Dot Clock and will
show the daily sunrise time (within 5 minutes) and sunset time (within 5 minutes) These calculated times
are MMBasic computed using the latitude and longitude location of the Outback Dot Clock plus GMT hour offset.
Software and hardware are now done.
Now on to the Outback Dot Clock packaging design.
Very crude photos of the clock below ...
2012-03-03_001719_Outback_Dot_Clock.pdf
Better photos
2012-03-03_005336_Better_Photos_Outback_Dot_Clock.pdf
Edited by DuinoMiteMegaAn 2012-03-04
Posted: 11:33pm 02 Mar 2012
That is so neat.
What I like is that it just runs with no complications, just one glance and you can tell the time. And it will run for so long. On top of that you get sunrise/sunset. The calculations for that would have taken a heap of work.
DuinoMiteMegaAn
Posted: 12:06am 03 Mar 2012
Board member TassyJim's algorithm was the most accurate and precise. The credit goes to him!
Link: http://www.thebackshed.com/forum/forum_posts.asp?TID=4434&KW =sunrise+sunset
BTW Geoff having no line numbers and defined subroutines helped alot in this project!
Here is my beta code for this Outback Dot Clock ...
Check out the sunrise sunset algorithm at the bottom - awesome!
'--------- Main_R1.bas --------------------
'Project: Outback Dot Clock Rev. 1.0b
'Author: Hacker - DuinoMiteMegaAndy
'Date: 2/3/2012
'App. Version: Rev. 1.0b
'MMBasic Firmware: 3.1 MaxiMite CGStick
'Platform: Win XP/SP3
'Bugs: DO NOT run I2C at 400 KHZ! Gives unknown line feeds in terminal programs.
'----------Code Begin--------------
' MAIN
OPTION BASE 0
'Spring Forward and Fall Back Dates for time change at 02:00 AM.
'DST data date format matches PIC32 Date$: Month/Day/Year xxxx
DATA "11-3-2012","4-11-2012","10-3-2013","11-3-2013","9-3-2014"
DATA "2-11-2014", "8-3-2015","1-11-2015","13-3-2016","6-11-2016"
DATA "12-3-2017","5-11-2017","11-3-2018","4-11-2018","10-3-2019"
DATA "3-11-2019"
DIM DSTDate$(16)
'Read data into zero base array
FOR I=0 TO 15 ' 8 years of DST dates
READ DSTDate$(I)
NEXT I
'initalize dat files
OPEN "B:LOCKOUT.dat" FOR OUTPUT AS #8:? #8, "FALSE":CLOSE #8 ' <-------------<<<<<<<<
DIM RTC_SECS, RTC_MINS, RTC_HRS, RTC_DOW, RTC_MON, RTC_DAY, RTC_YR
DIM MINS_SEG, HRS_SEG, DC_MID_HR, DC_CIV_HRS
DIM RTC_BUFF(6)
DS3231M_ADDRESS = 104 ' 0x68
RTC_SECS = 0: RTC_MINS = 0: RTC_HRS = 0: RTC_DOW = 1: RTC_MON = 1: RTC_DAY = 1: RTC_YR = 12
' setup GPIO
SET_GPIO
ZERO_SEGMENTS
? "PIC32 Time = ", TIME$
? "PIC32 Date = ", DATE$
RESET_CLOCK 3
' Sunrise time
SR_SS_Cal
PRINT "Sunrise time = ";
PRINT SR_Hr$;":";SR_Mn$
RTC_HRS = val(SR_Hr$)
RTC_MINS = val(SR_Mn$)
' display am/pm status red LED PM = ON
DISP_DOT_CLK_PM_AM_STATUS RTC_HRS
' re-calculate hours and minutes so the time display is in even increments of 5 mins
MINS_SEG = 0: DC_MID_HR = 0: DC_CIV_HRS = 0: HR_FLS_SPD = 0
CONV_RTC_MT_MINS_TO_CLK_SEGS RTC_MINS,MINS_SEG,DC_MID_HR 'convert to min seg 1-12
CONV_RTC_HRS_MT_TO_CIVILIAN RTC_HRS,DC_CIV_HRS 'convert to hours seg numbers 1-12
'mid hour time adjustment
IF (DC_MID_HR = 1) THEN DC_CIV_HRS = DC_CIV_HRS + 1: IF (DC_CIV_HRS > 12) THEN DC_CIV_HRS = 1
DISP_DOT_CLK_HR_SEG DC_CIV_HRS
DISP_DOT_CLK_MIN_SEG MINS_SEG
PAUSE 5000
ZERO_SEGMENTS
RESET_CLOCK 3
' Sunset time
SR_SS_Cal
PRINT "Sunset time = ";
PRINT SS_Hr$;":";SS_Mn$
RTC_HRS = val(SS_Hr$)
RTC_MINS = val(SS_Mn$)
PAUSE 5000
ZERO_SEGMENTS
'read and print analog sensors
PRT_TEMP
PRT_HUM
PRT_LIGHT
toggle = 1
timer = 0
START:
IF (timer > 1001) THEN
' Read DS3231M I2C RTC @ 1 second updates
I2Caddr = DS3231M_ADDRESS
I2CEN 100,100 ' Enable I2C 400 Khz 100 ms timeout
I2CRCV I2Caddr, 0, 7, RTC_BUFF(0), 1, 0
'? "0=ok 1=nack 2=timeout "; MM.I2C
I2CDIS
timer = 0
Pin(0) = toggle
toggle = not(toggle)
ENDIF
' convert RTC "hex" buffer to RTC "DEC" variables
PROCESS_RTC_BUFFER
DST_TIME_OK = 0
DST_DATE_OK = 0
IF ((RTC_HRS = 1) AND (RTC_MINS = 59)) THEN DST_TIME_OK = 1 ' 1:59 am
ELSE
DST_TIME_OK = 0
ENDIF
IF ( DST_TIME_OK = 1) THEN CHECK_DST_DATE DST_DATE_OK
IF ( DST_DATE_OK = 1) THEN PROCESS_DST
'? "rtc hrs = ", RTC_HRS
'? "mins segs =", mins_seg
'? "mid hr =", dc_mid_hr
'? "civian hrs", dc_civ_hrs
'? "MID HRS = ", DC_CIV_HRS
ZERO_SEGMENTS
'Tac switch #1 Display sensor values
IF (PIN(1) = 0) THEN RESET_CLOCK 3: DISPLAY_DC_TEMP: RESET_CLOCK 3: DISPLAY_DC_HUM: RESET_CLOCK 3: DISPLAY_DC_LIGHT
'Tac switch #2 Display DOW, Month, Day, Year
IF (PIN(7) = 0) THEN RESET_CLOCK 3: DISPLAY_DOW: RESET_CLOCK 3: DISPLAY_MONTH: RESET_CLOCK 3: DISPLAY_DAY: RESET_CLOCK 3: DISPLAY_YEAR
GOTO START ' loop forever
' Subroutines
SUB ZERO_SEGMENTS
Pin(8) = 0 ' 1 o'clock
Pin(9) = 0 ' 2 o'clock
Pin(10) = 0 ' 3 o'clock
Pin(14) = 1 ' 4 o'clock
Pin(15) = 1 ' 5 o'clock
Pin(16) = 1 ' 6 o'clock
Pin(17) = 1 ' 7 o'clock
Pin(18) = 1 ' 8 o'clock
Pin(19) = 1 ' 9 o'clock
Pin(20) = 1 ' 10 o'clock
Pin(11) = 1 ' 11 o'clock
Pin(5) = 0 ' 12 o'clock
Pin(6) = 0 ' pm/am
END SUB
SUB PRT_TEMP
DIM AVG,IDX, x
For idx=1 to 75: avg = avg + Pin(2): Next idx: avg = avg/75
x = (((((avg * 1000) - 500) / 10) * 1.8) + 32) + 3.5 '3.5 is cal offset
IF ((x <= 40) OR (x >= 95)) THEN ZERO_SEGMENTS: ? "Temperature Out Of Range!": FOR i = 1 TO 10: PIN(6) = 1: PAUSE 250: PIN(6) = 0: PAUSE 250: NEXT I: ZERO_SEGMENTS
? "Ambient Temperature F. = ", x
END SUB
SUB DISPLAY_DC_TEMP
local AVG,IDX, x, D1,D2, N$, I
IF ((x <= 40) OR (x >= 95)) THEN ZERO_SEGMENTS: FOR i = 1 TO 10: PIN(6) = 1: PAUSE 250: PIN(6) = 0: PAUSE 250: NEXT I: ZERO_SEGMENTS: END SUB
N$ = str$(abs(CINT(x)))
D2 = Val(LEFT$(N$,1))
D1 = Val(RIGHT$(N$,1))
IF D1 = 0 THEN D1 = 1 ' CANNOT SHOW ZERO
ZERO_SEGMENTS
PAUSE 2000
For I = 1 to 3
DISP_DOT_CLK_MIN_SEG(D2)
Pin(6) = 1
Pause 1000
ZERO_SEGMENTS
Next I
DISP_DOT_CLK_MIN_SEG(D1)
pause 2000
ZERO_SEGMENTS
END SUB
SUB PRT_LIGHT
local AVG,IDX,x
avg = 0: For idx=1 to 75: avg = avg + Pin(3): Next idx: avg = avg/75
x = avg
x = (x * 3.03)
x = abs(CINT(x))
IF x > 10 THEN x = 10
? "Light Voltage [DK=0 LT=10] = ", x
END SUB
SUB DISPLAY_DC_LIGHT
local AVG,IDX,x
x = avg
x = (x * 3.03)
x = abs(CINT(x))
ZERO_SEGMENTS
PAUSE 2000
'? "dc light = ", x
DISP_DOT_CLK_MIN_SEG(x)
Pin(6) = 1
Pause 2000
ZERO_SEGMENTS
END SUB
SUB PRT_HUM
LOCAL AVG,IDX,x,i
avg = 0: For idx=1 to 75: avg = avg + Pin(4): Next idx: avg = avg/75
x = (-23.82075472 + (47.64627406 * avg)) + 3.0 '(using 3.3 volts supply) 3 is cal offset
IF ((x <= 25) OR (x >= 55)) THEN ZERO_SEGMENTS: ? "Humidity Out Of Range!": FOR i = 1 TO 10: PIN(6) = 1: PAUSE 250: PIN(6) = 0: PAUSE 250: NEXT I: ZERO_SEGMENTS
? "Humidity RH% = ", x
END SUB
SUB DISPLAY_DC_HUM
LOCAL AVG,IDX,x,i,D1,D2, N$
IF ((x <= 25) OR (x >= 55)) THEN ZERO_SEGMENTS: ? "Humidity Out Of Range!": FOR i = 1 TO 10: PIN(6) = 1: PAUSE 250: PIN(6) = 0: PAUSE 250: NEXT I: ZERO_SEGMENTS: END SUB
ZERO_SEGMENTS
PAUSE 2000
For I = 1 to 3
Pin(6) = 1
Pause 1000
ZERO_SEGMENTS
Next I
PAUSE 2000
ZERO_SEGMENTS
END SUB
SUB DISPLAY_DOW
ZERO_SEGMENTS
PAUSE 2000
DISP_DOT_CLK_MIN_SEG(RTC_DOW)
Pin(6) = 1
Pause 2000
ZERO_SEGMENTS
END SUB
SUB DISPLAY_MONTH
ZERO_SEGMENTS
PAUSE 2000
DISP_DOT_CLK_MIN_SEG(RTC_MON)
Pin(6) = 1
Pause 2000
ZERO_SEGMENTS
END SUB
SUB DISPLAY_DAY
LOCAL D1,D2, N$
N$ = str$(RTC_DAY)
ZERO_SEGMENTS
PAUSE 2000
For I = 1 to 3
Pin(6) = 1
Pause 1000
ZERO_SEGMENTS
Next I
PAUSE 2000
ZERO_SEGMENTS
END SUB
SUB DISPLAY_YEAR
LOCAL D1,D2, N$
N$ = str$(RTC_YR)
ZERO_SEGMENTS
PAUSE 2000
For I = 1 to 3
Pin(6) = 1
Pause 1000
ZERO_SEGMENTS
Next I
PAUSE 2000
ZERO_SEGMENTS
END SUB
SUB SET_GPIO
'setpin 1,7, TAC 'tac sw1 4.7k pullup/330 ohm pulldown <------ H/L interrupt
setpin 1,2 ' tac sw1 4.7k pullup/330 ohm pulldown
setpin 2,1 ' tempF MCP9700
setpin 3,1 ' light AMBI 0-3.3V 0=dark 3.3= high light sensor
setpin 4,1 ' RH% HIH-5030 sensor
setpin 5,8 ' clock seg. 12 with 5V OC ext trans driv
setpin 6,8 ' pm/am - normal 3V output
'setpin 7,7, TAC tac sw2 4.7k pullup/300 ohm pulldown <------ H/L interrupt
setpin 7,2 ' tac sw2 4.7k pullup/300 ohm pulldown
setpin 8,8 ' clock seg. 1 with 5V OC ext trans driv
setpin 9,8 ' clock seg. 2 with 5V OC ext trans driv
setpin 10,8 ' clock seg. 3 with 5V OC ext trans driv
setpin 11,9 ' clock seg. 11 with on chip 5V OC trans driv
'setpin 12,8 <-- I2C SDA -- for ref only
'setpin 13,8 <-- I2C SCL -- for ref only
setpin 14,9 ' clock seg. 4 with on chip 5V OC trans driv
setpin 15,9 ' clock seg. 5 with on chip 5V OC trans driv
setpin 16,9 ' clock seg. 6 with on chip 5V OC trans driv
setpin 17,9 ' clock seg. 7 with on chip 5V OC trans driv
setpin 18,9 ' clock seg. 8 with on chip 5V OC trans driv
setpin 19,9 ' clock seg. 9 with on chip 5V OC trans driv
setpin 20,9 ' clock seg. 10 with on chip 5V OC trans driv
END SUB
SUB RESET_CLOCK(dcrep)
local TD
TD = 50
FOR I = 1 TO dcrep STEP 1
Pin(8) = 1 ' 1 o'clock
PAUSE TD
PAUSE TD
Pin(9) = 1 ' 2 o'clock
PAUSE TD
PAUSE TD
Pin(10) = 1 ' 3 o'clock
PAUSE TD
PAUSE TD
Pin(14) = 0 ' 4 o'clock
PAUSE TD
PAUSE TD
Pin(15) = 0 ' 5 o'clock
PAUSE TD
PAUSE TD
Pin(16) = 0 ' 6 o'clock
PAUSE TD
PAUSE TD
Pin(17) = 0 ' 7 o'clock
PAUSE TD
PAUSE TD
Pin(18) = 0 ' 8 o'clock
PAUSE TD
PAUSE TD
Pin(19) = 0 ' 9 o'clock
PAUSE TD
PAUSE TD
Pin(20) = 0 ' 10 o'clock
PAUSE TD
PAUSE TD
Pin(11) = 0 ' 11 o'clock
PAUSE TD
PAUSE TD
Pin(5) = 1 ' 12 o'clock
PAUSE TD
PAUSE TD
Pin(6) = 1 ' pm/am
PAUSE TD
Pin(6) = 0 ' pm/am
PAUSE 2 * TD
NEXT I
END SUB
SUB CONV_RTC_MT_MINS_TO_CLK_SEGS(MT_MINS,SEGS,MID_HR) ' for min hand range 0-59
IF ((MT_MINS >=1) AND (MT_MINS <=4)) THEN MID_HR = 0: SEGS = 1: RETURN
IF (MT_MINS = 5) THEN MID_HR = 0: SEGS = 1: RETURN
IF ((MT_MINS >=6) AND (MT_MINS <=9)) THEN MID_HR = 0: SEGS = 2: RETURN
IF (MT_MINS = 10) THEN MID_HR = 0: SEGS = 2: RETURN
IF ((MT_MINS >=11) AND (MT_MINS <=14)) THEN MID_HR = 0: SEGS = 3: RETURN
IF (MT_MINS = 15) THEN MID_HR = 0: SEGS = 3: RETURN
IF ((MT_MINS >=16) AND (MT_MINS <=19)) THEN MID_HR = 0: SEGS = 4: RETURN
IF (MT_MINS = 20) THEN MID_HR = 0: SEGS = 4: RETURN
IF ((MT_MINS >=21) AND (MT_MINS <=24)) THEN MID_HR = 0: SEGS = 5: RETURN
IF (MT_MINS = 25) THEN MID_HR = 0: SEGS = 5: RETURN
IF ((MT_MINS >=26) AND (MT_MINS <=29)) THEN MID_HR = 0: SEGS = 6: RETURN
IF (MT_MINS = 30) THEN MID_HR = 0: SEGS = 6: RETURN ' change 1 to 0
IF ((MT_MINS >=31) AND (MT_MINS <=34)) THEN MID_HR = 1: SEGS = 7: RETURN
IF (MT_MINS = 35) THEN MID_HR = 1: SEGS = 7: RETURN
IF ((MT_MINS >=36) AND (MT_MINS <=39)) THEN MID_HR = 1: SEGS = 8: RETURN
IF (MT_MINS = 40) THEN MID_HR = 1: SEGS = 8: RETURN
IF ((MT_MINS >=41) AND (MT_MINS <=44)) THEN MID_HR = 1: SEGS = 9: RETURN
IF (MT_MINS = 45) THEN MID_HR = 1: SEGS = 9: RETURN
IF ((MT_MINS >=46) AND (MT_MINS <=49)) THEN MID_HR = 1: SEGS = 10: RETURN
IF (MT_MINS = 50) THEN MID_HR = 1: SEGS = 10: RETURN
IF ((MT_MINS >=51) AND (MT_MINS <=54)) THEN MID_HR = 1: SEGS = 11: RETURN
IF (MT_MINS = 55) THEN MID_HR = 1: SEGS = 11: RETURN
IF ((MT_MINS >=56) AND (MT_MINS <=59)) THEN MID_HR = 1: SEGS = 12: RETURN
IF (MT_MINS > 59) THEN RETURN ' added
IF (MT_MINS = 0) THEN MID_HR = 0: SEGS = 12: RETURN
IF (MT_MINS < 1) THEN MID_HR = 0: SEGS = 12: RETURN 'added
END SUB
SUB CONV_RTC_HRS_MT_TO_CIVILIAN(MT_HRS,CIV_HRS)
IF ((MT_HRS >= 13) AND (MT_HRS <= 23)) THEN CIV_HRS = (MT_HRS - 12): RETURN
IF ((MT_HRS >= 0) AND (MT_HRS <= 12)) THEN CIV_HRS = MT_HRS: RETURN
END SUB
SUB DISP_DOT_CLK_PM_AM_STATUS(MT_HRS) ' between 13:xx to 24:xx - military time 0-23 hrs
'Turn on dot clock red PM/AM status LED
IF ((MT_HRS >= 12) AND (MT_HRS <= 23)) THEN Pin(6)= 1
ELSE
'Turn off dot clock red PM/AM status to indicate AM
Pin(6) = 0
ENDIF
END SUB
SUB DISP_DOT_CLK_MIN_SEG(MIN_HAND) ' do not flash
IF (MIN_HAND = 1) THEN Pin(8) = 1: RETURN ' 1 o'clock
IF (MIN_HAND = 2) THEN Pin(9) = 1: RETURN ' 2 o'clock
IF (MIN_HAND = 3) THEN Pin(10) = 1: RETURN ' 3 o'clock
IF (MIN_HAND = 4) THEN Pin(14) = 0: RETURN ' 4 o'clock
IF (MIN_HAND = 5) THEN Pin(15) = 0: RETURN ' 5 o'clock
IF (MIN_HAND = 6) THEN Pin(16) = 0: RETURN ' 6 o'clock
IF (MIN_HAND = 7) THEN Pin(17) = 0: RETURN ' 7 o'clock
IF (MIN_HAND = 8) THEN Pin(18) = 0: RETURN ' 8 o'clock
IF (MIN_HAND = 9) THEN Pin(19) = 0: RETURN ' 9 o'clock
IF (MIN_HAND = 10) THEN Pin(20) = 0: RETURN ' 10 o'clock
IF (MIN_HAND = 11) THEN Pin(11) = 0: RETURN ' 11 o'clock
IF (MIN_HAND = 12) THEN Pin(5) = 1: RETURN ' 12 o'clock
END SUB
SUB DISP_DOT_CLK_HR_SEG(HR_HAND)
IF (HR_HAND = 0) THEN FLASHX1(5): RETURN
IF (HR_HAND = 1) THEN FLASHX1(8): RETURN
IF (HR_HAND = 2) THEN FLASHX1(9): RETURN
IF (HR_HAND = 3) THEN FLASHX1(10): RETURN
IF (HR_HAND = 4) THEN FLASHX2(14): RETURN
IF (HR_HAND = 5) THEN FLASHX2(15): RETURN
IF (HR_HAND = 6) THEN FLASHX2(16): RETURN
IF (HR_HAND = 7) THEN FLASHX2(17): RETURN
IF (HR_HAND = 8) THEN FLASHX2(18): RETURN
IF (HR_HAND = 9) THEN FLASHX2(19): RETURN
IF (HR_HAND = 10) THEN FLASHX2(20): RETURN
IF (HR_HAND = 11) THEN FLASHX2(11): RETURN
IF (HR_HAND = 12) THEN FLASHX1(5) : RETURN
END SUB
SUB FLASHX1(pf1)
FOR i=1 TO 10
Pin(pf1) = 1
PAUSE 50
Pin(pf1) = 0
PAUSE 50
NEXT i
RETURN
END SUB
SUB FLASHX2(pf2)
FOR i=1 TO 10
Pin(pf2) = 0
PAUSE 50
Pin(pf2) = 1
PAUSE 50
NEXT i
RETURN
END SUB
SUB PROCESS_RTC_BUFFER
BCDTEMP = RTC_Buff(0) 'secs (00-59)
Decimal = FIX(BCDTemp / 16) * 10: Decimal = Decimal + (BCDTEMP AND &hF)
RTC_SECS = decimal
'? "rtc secs = ", RTC_SECS
BCDTEMP = RTC_Buff(1) ' mins (00-59)
RTC_MINS = decimal
'? "rtc mins = ", RTC_MINS
BCDTEMP = RTC_Buff(2) ' hours (00-23) --> In military time!
RTC_HRS = decimal
BCDTEMP = RTC_Buff(3) ' dow - day of week (1-7) Sunday = 1
RTC_DOW = decimal
'? "rtc dow = ", RTC_DOW
BCDTEMP = RTC_Buff(4) ' date --> day of month (01-31)
RTC_DAY = decimal
'? "rtc day = ", RTC_DAY
BCDTEMP = RTC_Buff(5) ' month - (01-12)
RTC_MON = decimal
'? "rtc month = ", RTC_MON
BCDTEMP = RTC_Buff(6) ' year - (00-99) Needs + 2000
'decimal = decimal + 2000 ' adjust year + 2000
RTC_YR = decimal
'? "rtc year = ", RTC_YR
END SUB
SUB CHECK_DST_DATE(date_ok)
Local key$
IF DATE$ = DSTDate$(I) THEN GOTO DST_FOUND
NEXT I
'? "DST Key Not Found!"
OPEN "B:LOCKOUT.dat" FOR INPUT AS #8:INPUT #8, key$ :CLOSE #8 '<------<<<<<<<<<<<<& lt;
'reset dst lockout when the date changes from the "dst day"
IF (key$ = "TRUE") THEN OPEN "B:LOCKOUT.dat" FOR OUTPUT AS #8:? #8, "FALSE":CLOSE #8 ' <-------<<<<<
date_ok = 0: END SUB
DST_FOUND:
date_ok = 1
END SUB
SUB PROCESS_DST
Local key$
OPEN "B:LOCKOUT.dat" FOR INPUT AS #8:INPUT #8, key$ :CLOSE #8 ' <---------<<<<<<<<
'stop multiple dst updates in one day
IF (key$ = "TRUE") THEN END SUB
'read CGStick RTC
tempdec = VAL(LEFT$(TIME$, 2))
hours_dec = tempdec
hex = FIX(tempdec / 10) * 16: hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10
hours = hex
tempdec = VAL(MID$(TIME$, 4, 2))
minutes = hex
tempdec = VAL(RIGHT$(TIME$, 2))
seconds = hex
tempdec = VAL(LEFT$(DATE$, 2))
DOW_DAY = tempdec
day = hex
tempdec = VAL(MID$(DATE$, 4, 2))
month_dec = tempdec
month = hex
tempdec = (VAL(RIGHT$(DATE$, 4)) - 2000)
DOW_Year = tempdec
year = hex
a = (14 - dow_month) / 12
a = FIX(a)
y = dow_year - a
y = FIX(y)
m = dow_month + (12 * a) - 2
m = FIX(m)
d = ((dow_day + y) + FIX(y / 4) - FIX(y / 100) + FIX(y / 400) + FIX((31 * m) / 12))
DOW = d MOD 7
DOW = DOW + 1 ' offset for DS3231/DS1307 RTC --> Sun(1)Mon(2)Tue(3)Wed(4)Thu(5)Fri(6)Sat(7)
tempdec = DOW ' DOW dec
IF month_dec = 3 THEN GOTO ADD1 'Spring forward +1 hr
IF month_dec = 11 THEN GOTO SUB1 'Fall back -1 hr
'? "ABORT ---> DST Month Error!" ' check your DST array above!
END SUB
ADD1: IF hours_dec = 23 THEN hours_dec = 0: hex = FIX(tempdec / 10) * 16: hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10: GOTO DST_UPDATE ' ADD +1 to military time
IF hours_dec >= 0 AND hours_dec < 23 THEN hours_dec = hours_dec + 1:hex = FIX(tempdec / 10) * 16:hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10: GOTO DST_UPDATE ' ADD +1 to military time
'? "error add1"
END SUB
SUB1: IF hours_dec >= 1 AND hours_dec <= 23 THEN hours_dec = hours_dec - 1:hex = FIX(tempdec / 10) * 16:hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10: GOTO DST_UPDATE ' SUBTRACT -1 to military time
IF hours_dec = 0 THEN hours_dec = 23: hex = FIX(tempdec / 10) * 16:hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10: GOTO DST_UPDATE 'SUBTRACT -1 to military time
'? "error sub1"
END SUB
DST_UPDATE:
rtcwday= hex
' Write DST adjusted Time to DS3231 RTC
i2caddr = DS3231M_ADDRESS
I2CSEND i2caddr, 0, 8, &h0, seconds, minutes, hours_dec, rtcwday, day, month, year
'? "0=ok 1=nack 2=timeout"; MM.I2C
I2CDIS
? "DST has updated the DS3231 RTC!"
OPEN "B:DST.dat" FOR APPEND AS #9: ? #9,"RTC_DST_UPDATED":? #9,DATE$:? #9,TIME$:? #9,"<------>":CLOSE #9
OPEN "B:LOCKOUT.dat" FOR OUTPUT AS #8:? #8, "TRUE":CLOSE #8 '<--------<<<<<<<<<<
END SUB
' ISRs - DISABLED
'Tac switch #1
'TAC: IF (PIN(1) = 0) THEN
'Tac switch #2
'IF (PIN(7) = 0) THEN
'IRETURN
' Sunrise-Sunset Calculation (SEE CREDITS BELOW)
SUB SR_SS_Cal
DIM A(2), D(2)
SR_SS_Lockout = 0
SR_SS_CONSTANTS
'Location - Columbus,Ohio USA 39 59' North 82 59' West
'Enter north latitudes positive, west longitudes negative
'INPUT "Lat-deg="; B5
B5 = 40 ' in dec <--------- Location Lat in dec.
'INPUT "Long-deg="; L5
L5 = -82.88 'in dec <------- Location Long in dec.
'INPUT "Time zone-hrs="; H
H = 5 ' EDT Eastern standard daylight savings time <--- Location time zone EDT OR EST
L5 = L5 / 360: Z0 = H / 24
SR_SS_CALENDAR
T = (J - 2451545) + F
TT = T / 36525 + 1 ' TT = centuries
' from 1900.0
SR_SS_TIME_ZONE
T = T + Z0
' Get Sun's Position
SR_SS_FUN_ARGS
A(1) = A5: D(1) = D5
T = T + 1
SR_SS_FUN_ARGS
A(2) = A5: D(2) = D5
IF A(2) < A(1) THEN A(2) = A(2) + P2
Z1 = DR * 90.833 ' Zenith dist.
S = SIN(B5 * DR): C = COS(B5 * DR)
Z = COS(Z1): M8 = 0: W8 = 0
A0 = A(1): D0 = D(1)
DA = A(2) - A(1): DD = D(2) - D(1)
FOR C0 = 0 TO 23
P = (C0 + 1) / 24
A2 = A(1) + P * DA: D2 = D(1) + P * DD
SR_SS_COMPUTE
A0 = A2: D0 = D2: V0 = V2
NEXT
SR_SS_PRINT_MESSAGE
'INPUT "Hit CR To Continue "; Query$
ERASE A ' FOR RE-ENTRY
ERASE D ' FOR RE-ENTRY
'END
END SUB
SUB SR_SS_CONSTANTS
' Constants
P1 = 3.14159265
P2 = 2 * P1
DR = P1 / 180
K1 = 15 * DR * 1.0027379
S$ = "Sunset at "
R$ = "Sunrise at "
M1$ = "No sunrise this date"
M2$ = "No sunset this date"
M3$ = "Sun down all day"
M4$ = "Sun up all day"
END SUB
SUB SR_SS_CALENDAR
' Calendar --> JD
'INPUT "Year= "; Y
Y = VAL(RIGHT$(DATE$, 4)) ' <----- From PIC32 RTC YYYY
'INPUT "Month= "; M
M = VAL(MID$(DATE$, 4, 2))' <----- From PIC32 RTC
'INPUT "Day= "; D
D = VAL(LEFT$(DATE$, 2)) ' <------ From PIC32 RTC
G = 1: IF Y < 1583 THEN G = 0
D1 = INT(D): F = D - D1 - .5
J =0 -INT(7 * (INT((M + 9) / 12) + Y) / 4)
IF G = 0 THEN GOTO SR_SS_LABEL_1
S = SGN(M - 9): A = ABS(M - 9)
J3 = INT(Y + S * INT(A / 7))
J3 =0 -INT((INT(J3 / 100) + 1) * 3 / 4)
SR_SS_LABEL_1: J = J + INT(275 * M / 9) + D1 + G * J3
J = J + 1721027 + 2 * G + 367 * Y
IF F >= 0 THEN END SUB
F = F + 1: J = J - 1
END SUB
SUB SR_SS_TIME_ZONE
' LST at 0h zone time
T0 = T / 36525
S = 24110.5 + 8640184.812999999 * T0
S = S + 86636.6 * Z0 + 86400 * L5
S = S / 86400: S = S - INT(S)
T0 = S * 360 * DR
END SUB
SUB SR_SS_FUN_ARGS
' Fundamental arguments
' (Van Flandern &
' Pulkkinen, 1979)
L = .779072 + .00273790931 * T
G = .993126 + .0027377785 * T
L = L - INT(L): G = G - INT(G)
L = L * P2: G = G * P2
V = .39785 * SIN(L)
V = V - .01 * SIN(L - G)
V = V + .00333 * SIN(L + G)
V = V - .00021 * TT * SIN(L)
U = 1 - .03349 * COS(G)
U = U - .00014 * COS(2 * L)
U = U + .00008 * COS(L)
W = -.0001 - .04129 * SIN(2 * L)
W = W + .03211 * SIN(G)
W = W + .00104 * SIN(2 * L - G)
W = W - .00035 * SIN(2 * L + G)
W = W - .00008 * TT * SIN(G)
' Compute Sun's RA and Dec
S = W / SQR(U - V * V)
A5 = L + ATN(S / SQR(1 - S * S))
S = V / SQR(U): D5 = ATN(S / SQR(1 - S * S))
R5 = 1.00021 * SQR(U)
END SUB
SUB SR_SS_COMPUTE
' Test an hour for an event
L0 = T0 + C0 * K1: L2 = L0 + K1
H0 = L0 - A0: H2 = L2 - A2
H1 = (H2 + H0) / 2 ' Hour angle,
D1 = (D2 + D0) / 2 ' declination,
' at half hour
IF C0 > 0 THEN GOTO SR_SS_LABEL_3
V0 = S * SIN(D0) + C * COS(D0) * COS(H0) - Z
SR_SS_LABEL_3: V2 = S * SIN(D2) + C * COS(D2) * COS(H2) - Z
IF SGN(V0) = SGN(V2) THEN END SUB
V1 = S * SIN(D1) + C * COS(D1) * COS(H1) - Z
A = 2 * V2 - 4 * V1 + 2 * V0: B = 4 * V1 - 3 * V0 - V2
D = B * B - 4 * A * V0: IF D < 0 THEN END SUB
D = SQR(D)
'IF V0 < 0 AND V2 > 0 THEN PRINT R$;
IF V0 < 0 AND V2 > 0 THEN M8 = 1
'IF V0 > 0 AND V2 < 0 THEN PRINT S$;
IF V0 > 0 AND V2 < 0 THEN W8 = 1
E = (0-B + D) / (2 * A)
IF E > 1 OR E < 0 THEN E = (0-B - D) / (2 * A)
T3 = C0 + E + 1 / 120 ' Round off
H3 = INT(T3): M3 = INT((T3 - H3) * 60)
Hr$=str$(H3):Hr$=right$("0"+Hr$,2):Mn$=str$(M3):Mn$=right$(" 0"+Mn$,2)
IF ( SR_SS_Lockout = 1) THEN GOTO SR_SS_LABEL_4
'PRINT Hr$;":";Mn$;
SR_Hr$ = Hr$
'? "SR HRS = ", SR_Hr$
SR_Mn$ = Mn$
'? "SR Mins = ", SR_Mn$
SR_SS_Lockout = 1
ELSE
'SR_SS_LABEL_4: PRINT Hr$;":";Mn$;
SR_SS_LABEL_4: SS_Hr$ = Hr$
'? "SS HRS = ", SS_Hr$
SS_Mn$ = Mn$
'? "SS Mins = ", SS_Mn$
SR_SS_Lockout = 0
ENDIF
H7 = H0 + E * (H2 - H0)
N7 =0 -COS(D1) * SIN(H7)
D7 = C * SIN(D1) - S * COS(D1) * COS(H7)
AZ = ATN(N7 / D7) / DR
IF D7 < 0 THEN AZ = AZ + 180
IF AZ < 0 THEN AZ = AZ + 360
IF AZ > 360 THEN AZ = AZ - 360
'PRINT ", azimuth ";
'PRINT AZ
END SUB
SUB SR_SS_PRINT_MESSAGE
' Special-message routine
IF M8 = 0 AND W8 = 0 THEN SR_SS_LABEL_5
IF M8 = 0 THEN PRINT M1$
IF W8 = 0 THEN PRINT M2$
END SUB
SR_SS_LABEL_5: IF V2 < 0 THEN PRINT M3$
IF V2 > 0 THEN PRINT M4$
END SUB
' Credits: The Back Shed forum board member TassyJim ("spot on the minute") and ...
' This program by Roger W. Sinnott calculates the times of sunrise
' and sunset on any date, accurate to the minute within several
' centuries of the present. It correctly describes what happens in the
' arctic and antarctic regions, where the Sun may not rise or set on
' a given date. Enter north latitudes positive, west longitudes
' negative. For the time zone, enter the number of hours west of
' Greenwich (e.g., 5 for EST, 4 for EDT). The calculation is
' discussed in Sky & Telescope for August 1994, page 84.
B:\> memory
24kB (81%) Program memory used <----------
5kB (38%) Variable memory used
8kB (23%) General memory used
29kB Free on the heap
Enjoy
centrex
Posted: 02:51am 04 Mar 2012
hi Duino-Andy
Just wondering where you got the 8pin rtc from as all my searching of suppliers I only come up with the 16pin version. Any reason for using the 8pin version as it appears to have a lower spec than the 16pin version.
Cliff
Cliff
DuinoMiteMegaAn
Posted: 03:17am 04 Mar 2012
Both Mouser and Digikey carry this DS3231M. I bought mine from Digikey
# DS3231MZ+-ND (plus dash ND)
Having a 8 pin SOIC is alot easier for board layout and hand soldering. At 0.432 seconds per day works out to be 158 seconds per year or 158/60 - 2.68 minutes. I can live with that on the dot clock since it reads out every 5 minutes. On my Outback Dot Clock sensor board, I also added a place to install the
-+ 2 ppm ChronoDot for better accuracy. The ChronoDot cost $16 which is fairly expensive.
Edited by DuinoMiteMegaAn 2012-03-05
DuinoMiteMegaAn
Posted: 01:42pm 04 Mar 2012
@ Centrex - Preliminary attached Outback Dot Clock schematic.
Note: The PCB house we went to was very expensive and this PCB design used their software for the prototype printed circuit board. The silkscreen and soldermask are required for this design.
2012-03-04_234052_Outback_Dot_Clock_Schematic_R1.pdf
Enjoy Edited by DuinoMiteMegaAn 2012-03-05
centrex
Posted: 03:23am 17 Mar 2012
Hi
I may be missing something but where are the daylight saving times for?
According to the NSW Gov site dst starts on the 1st Sunday in October and finishes on the 1st Sunday in April.
I cannot see any of these dates in the data file of the clock.
As I said I may be missing something but I need pointing in the right direction.
Cliff
Cliff
DuinoMiteMegaAn
Posted: 03:35am 17 Mar 2012
The reason why you don't see Australian DST dates is because I am an American
Please search the internet for your projected 8 years of DST dates and install
yours in the data table.
An American is not equal to a fine Australian. <-----<<<<<<
' MAIN
OPTION BASE 0
'DST data date format matches PIC32 Date$: Day-Month-Year yyyy is 10 chars in Length! <------<<<<<<<<<<<<
DATA "11-03-2012","04-11-2012","10-03-2013","11-03-2013","09-03-2 014"
DATA "02-11-2014","08-03-2015","01-11-2015","13-03-2016","06-11-2 016"
DATA "12-03-2017","05-11-2017","11-03-2018","04-11-2018","10-03-2 019"
DATA "03-11-2019"
Make sure you have 10 chars to compare! Edited by DuinoMiteMegaAn 2012-03-18
centrex
Posted: 03:53am 17 Mar 2012
That explanes it all, the location "Australia" in your profile confused the issue.
Cliff
DuinoMiteMegaAn
Posted: 01:14pm 17 Mar 2012
@centrex
Also, patch this code snippet with your months of April and October (4 & 10)
END SUB
