Local Time 21:47 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to install an uSD card on the CGMMSti
DuinoMiteMegaAn
Posted: 08:11pm 26 Feb 2012
The card will not pass over the firmware jumper and the metal crystal?
This must be cruel joke or trick or a serious PCB layout problem?
BobD
Posted: 08:27pm 26 Feb 2012
No, if I recall correctly, the holder opens up like a hinge, you insert the card and then close it back down. CG has written a document on his creation and that may tell all.
BobD
Posted: 08:32pm 26 Feb 2012
Bigmik knows how. Look here http://www.thebackshed.com/forum/forum_posts.asp?TID=4572&PN =4
DuinoMiteMegaAn
Posted: 08:42pm 26 Feb 2012
Whew ... gently pull back the SD holder to the edge horizonally to unlock then lift the sd holder hinge up then insert the card. Reverse the process.
edited ...
The CGMMStick is slick Edited by DuinoMiteMegaAn 2012-02-28
