Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MERGE command question
BobDevries
Posted: 01:30am 24 Feb 2012
Hi all,
QUESTION: Is the MERGE command suitable for use inside a programme?
I have tried to do this, and it seems that while the merge does take place; that is, the requested file is added to the end of the programme space, the programme doesn't run beyond that command, or, the MERGE puts the programme pointer at the end of the BASIC programme in memory, which then quits silently.
MERGE "ISLEGAL.SUB":REM name of subroutine on SD card
for x=1 to 10
print x;
next x
Comments?
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 01:32am 24 Feb 2012
hehe,
I guess what I'm asking is: Is this a BUG or a FEATURE?
Bob Devries
djuqa
Posted: 01:44am 24 Feb 2012
feature
MERGE is designed to create a runnable / usable program from snippets / short programs. (especially useful for Defined subroutines)
Merge is not designed to be a RUNTIME command.Edited by djuqa 2012-02-25
VK4MU MicroController Units
James_From_Canb
Posted: 07:18am 01 Mar 2012
I've edited this post to take out an example of the Merge not working as I expected.
After a bit more experimentation I agree that MERGE is not designed to be included in the code and executed. If you run the program multiple times, it adds multiple copies of the merge code at the end of the user code. If you run it once, it adds the merge code once, but just returns to the command prompt. That means it won't execute properly the first time. You could run it a second time and use a flag to check whether the library has already been merged, but running a program twice is not intuitive for users.
If the merge is designed to work from the command prompt the user will have to know which libraries to add before running the program. Subroutines could be worse as there are likely to be more of them if they're not in a library.
Given that there is no batch file support, does anyone have any suggestions on how the libraries/subroutines can be loaded without input by the users?
JamesEdited by James_From_Canb 2012-03-02
