Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Working with usb
Juri74
Posted: 03:27pm 20 Feb 2012
Question: is it possible to use the usb port like a serial port? i mean i want to connect my duinomite with my UBW32 using the usb, can i use one of them like a pc and access the other throug the serial function with usb cable?
juri
Olimex
Posted: 04:47pm 20 Feb 2012
yes, it's possible DM can be USB host but the current firmware do not support this
Juri74
Posted: 04:50pm 20 Feb 2012
thank you Olimex, and do you know if is it possible with maximite basic 3.1 firmware?
Juri
Olimex
Posted: 06:51pm 20 Feb 2012
to the best of my knowledge no it's not possible
Juri74
Posted: 11:56pm 20 Feb 2012
thank you again Olimex
Juri
djuqa
Posted: 12:26am 21 Feb 2012
Why not just use the Serial ports on both boards to talk to each other
Connected directly the 2 boards should transfer data fast enough for most needs.
Edited by djuqa 2012-02-22
VK4MU MicroController Units
Juri74
Posted: 01:10am 21 Feb 2012
  djuqa said   Why not just use the Serial ports on both boards to talk to each other
because i haven't maximite basic on UBW32 but it's native firmware, may i set a serial port on some pins of the ubw32 and use it to send commands?
Juri
