Forum Index : Microcontroller and PC projects : DuinoMite now have CAN BASIC commands
Olimex
Posted: 11:30am 17 Feb 2012
Good News!
Frank have add CAN support the comands are described HERE
CAN BASIC demo code is HERE
Ken will update the firmware and post the source and HEX to the firmware update thread.
The CAN support opens a lot of interesting application.
CAN is just one very reliable networking protocol for noisy environments and used in every car and many Industrial robots.
CAN now allow many DuinoMites to talk to each other via CAN bus by just two wires.
CAN also is used in the cars, all sensors, actuators, Engine ECU read and write info via this protocol, so by connecting to this bus you can read your engine temprature, RPMs, fuel consumption and every car sensor info and build something like THIS for instance
djuqa
Posted: 11:49am 17 Feb 2012
Great work
Document Listing the OBDII AUstralian Standard Unique PinoutEdited by djuqa 2012-02-18
VK4MU MicroController Units
Juri74
Posted: 12:31pm 17 Feb 2012
Great, Great work!!!
Posted: 11:19am 18 Feb 2012
This is great news!
For cars.... what MOV/TVS/etc should be used and where? They have way too many parameters for a non-electronics whizz :(
(clamp voltage, AC V, DC V, energy, ... aargh)
I expect something's needed for the 12V (as if: more like 13-15V) supply. What?
Is something also needed for the CAN or is the MCP2551 enough? (I suspect it is.)
amorosik
Posted: 08:44am 26 Feb 2012
  Olimex said   Good News!
Where is possible to find firmware update for can bus command on DuinoMite?
djuqa
Posted: 11:25am 26 Feb 2012
Download available HERE
Lopezjm2001
Posted: 02:27am 09 Jul 2012
  djuqa said   Download available HERE
Thanks for the link. The download worked but I do not have a keyboard and my Teraterm program will not work. It was working previously with mmbasic 3.2 when I found that mmbasic does not support Canbus commands. Cannot find a device driver for Duinomite Composite Device so that Duinomite Mega USB will communicate with my PC. I do not have a keyboard just a notebook. Thanks.Edited by Lopezjm2001 2012-07-10
Lopez
DuinoMiteMegaAn
Posted: 03:05am 09 Jul 2012
This is great news but I switched from DuinoMite firmware and NEVER looked back to the "quality controlled" bug free firmware from Geoff G, the founder of MaxiMite and MMBasic. Until CAN is available from Geoff G, I would stay away from this DM vintage of firmware.
donmck
Posted: 08:29am 09 Jul 2012
Read:
http://www.duinomite.com/duinomite-firmware-update-guide/
This may help.
Don...
https://www.dontronics.com
