Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic "Open" cmd
paceman
Posted: 08:01am 13 Feb 2012
I'm trying to implement Bryan1's HelpV2 text files on my Maximite using MMBasic V3.1. I have a folder on the SD B: drive called "HELPV2" which contains all of Bryan's .txt files for the different commands and functions and have put a small program called "HELP.BAS" (listed below) in the B: root of the SD drive. When I run HELP.BAS it gets to the "OPEN" command in the file reading/printing subroutine "prntfile (query$)" and then gives an error saying it can't find the file.
I've tried all sorts of variations here but can't get it working. Can someone tell me what I'm doing wrong please?
Greg
Cls
Line Input "Which command?: ",query$
If query$ = Chr$(27) Then
Exit
Else
Cls: prntfile (query$)
EndIf
Loop Until query$ = Chr$(27)
Print "Return to the original program"
End
' Subroutine to open and print the cmd/func file
Sub prntfile (filename$)
filename$ = "b:\v2help\"+filename$+".txt"
Print "filename$ =",filename$
Open filename$ For input As #1
Line Input #1 info$
Print info$
Loop Until eof
Close #1
End SubEdited by paceman 2012-02-14
Posted: 09:54am 13 Feb 2012
The only thing that I can see is that the line:
Line Input #1 info$
Should be:
Line Input #1, info$
But that does not sound like your particular problem.
crackerjack
Posted: 09:58am 13 Feb 2012
You say you have a folder called "HELPV2" but your program is atrying to access a file in a folder called "V2HELP" - is that it?
Also, it would be more efficient to code the main loop as follows:
[code]
Do While query$ <> Chr$(27)
Loop
[/code]
Also, just out of interest - how do you enter Character 27 from the keyboard?
Gadget
Posted: 11:31am 13 Feb 2012
character 27 is the standard ascii code for escape, without checking the manual I'd say it is the escape key
paceman
Posted: 01:22pm 13 Feb 2012
Thanks Geoff and CrackerJack, I've fixed both these but it still throws "Error: Cannot find file" on the open staement. Can't believe I swapped "helpv2" and "v2help"
Any other ideas?
Greg
paceman
Posted: 01:26pm 13 Feb 2012
Yes, it's the ESC key
Greg
paceman
Posted: 01:30pm 13 Feb 2012
[code]
Loop
[/code]
Thanks for this too - I've "room for improvement" as my teachers used to say!
Greg
paceman
Posted: 01:46pm 13 Feb 2012
I should have included the new version - which still can't find the file.
Cls
Line Input "which command?: ",query$
Loop
filename$ = "b:\helpv2\"+filename$+".txt"
Print info$
Loop Until eof
Close #1
End Sub
BobD
Posted: 06:39pm 13 Feb 2012
assuming drive B: as the default, I tried this
filename$="B:\example.txt"
open filename$ for input as 1
and it fails. If I take out the B: so the program is
filename$="\example.txt"
that works. The MM Basic Manual V3.1 says in part for the OPEN command
Opens a file for reading or writing
‘fname’ is the filename (8 chars max) with an optional extension (3 chars
max) separated by a dot (.). It can be prefixed with a directory path. For
example: "B:\DIR1\DIR2\FILE.EXT".
and so it looks like a bug to me or change the manual. The work around looks like changing to the drive before issuing the command.Edited by BobD 2012-02-15
paceman
Posted: 11:36pm 13 Feb 2012
Hi BobD,
Excellent, thanks for that, I'll give it a go when I've done a couple of my better half's jobs. I read that in the manual too so maybe Geoff does have a teensy bug.
Greg
BobD
Posted: 04:36am 14 Feb 2012
  paceman said   Hi BobD,
Greg
Mr Paceman
You were a bit stiff with this one, a typo and a real bug both st the same time. I have been advised this was the first report of it and it's on the do list for fixing in V3.2. At least you can easily work around it.
paceman
Posted: 10:46am 14 Feb 2012
Hi Bob,
Oops, Geoff was very helpful to me yesterday with another issue and now I've given him another hassle!
I've changed the directory and by leaving the drive designation off the filename$ build it seems to run. I say seems because it flashes onto the screen what looks like the appropriate queried help file but immediately erases it and hangs. Control comes back OK with cntrl'c' but for some reason the cursor is at the bottom of the screen. Also the CHR$(27) (ESC character) doesn't seem to be working in the main program.
Were you suggesting something slightly different for a workaround?
Greg
Current code:
Line Input "Which command or function?: ",query$
prntfile (query$)
Loop
' Subroutine to open and print the queried cmd/func help file
Cls
Chdir "b:\helpv2\"
filename$ = "\helpv2\"+filename$+".txt" 'this works but not if b: included
'filename$ = filename$ + ".txt" 'this doesn't work
Print info$
Loop Until eof
Close #1
Chdir ".."
End Sub
Edited by paceman 2012-02-15
Bryan1
Posted: 11:16am 14 Feb 2012
Hi Paceman,
When I first started on the Help file I did in basic but soon found I was running quickly out of program memory and it was suggested to do it in a text based system and Ken took it on to implement it software where on the DM as shown on the main help page changing the 'autorun.bas' file will when F1 is pressed the help file will come up. Also one can simply do
help " whatever
and if there is a file name name called 'whatever' the screen will blank out and that help file will be shown and what ever program you are working on is kept in program memory. Don also suggested by saving ones own files, code snippets, post it notes etc was also a feature so why Geoff hasn't done this 'help file system' for the MM is beyond me as I did say once I realeased it IS open source and free for users to improve, modify etc.
Now I did try that 3.1 on my mega DM and as soon as the help file didnt work I reflashed back to the latest DM firmware.
I did spend a great deal of time doing that for my first project so every user either new to this great idea or experienced users could look it up when and if required and for member to improve it.
Regards Bryan
paceman
Posted: 01:18pm 14 Feb 2012
Hi Bryan,
Yes I tried out your .BAS based system but decided your new .TXT one was a lot more flexible (editable files, more examples etc.). I'm trying to get it going on my Maximite much the same way you've described i.e. see the description I've included at the start of the code. I didn't include these comments in the previous posts to save space and keep my problem more in focus.
' .............HELP.BAS.............
' Print's Bryan1's help text files. The program is resident
' in the B: drive & launched by pressing the F5 key & typing
' "help". It assumes the .txt files are in a directory
' called HELPV2 on the SD card B: drive & that the command
' OPTION F5 = "RUN "+CHR$(34) has previously been run e.g.
' as by the MMBasic Library AUTORUN program.
It should be quick and easy to use this way for Maximite users and the little "HELP.BAS" program is pretty minimal. I thought about unloading and re-loading a program that might have been loaded but it's not necessary when you're using the full-screen editor. All that's needed is to use the editor's F2 key to RUN what you're editing, CTRL'C' back out, then get HELP with the F5 key (the key can be changed to F1 if you want with the OPTION Fx command e.g. in your AUTORUN program) .Typing in EDIT again brings the code you're editing back up.
Doing it this way is a simple way of implementing editable help text files using the current MMBasic code so it's not surprising that Geoff hasn't built a special function key command for it - that would probably also mean you couldn't change the key it's assigned to which would limit the OPTION Fx command. He may also have something quite different in mind.
Your efforts getting all the text files organised is appreciated I assume by everyone. This little program will just make them easier to access for the Maximite users if they haven't already done it for themselves.
Best Regards,
Greg
