Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) Some DuinoMite projects
Olimex
Posted: 07:11pm 01 Feb 2012
Every evening I have fun and try something with DM, here is list of some projects done by me and some done by Mathias Johansson, which I think may be interesting for some of you :)
GSM remote control with DuinoMite and MOD-GSM
Add voice and music to embedded projects with DuinoMite and MOD-MP3-X
Detecting knocks with DuinoMite and Piezzo Sensors
Hacking DuinoMite Basic
Measuring Earth's Magnetic field with MOD-MAG and DuinoMite
Interfacing DS1307 Real Time Clock with DuinoMite
Interfacing BMP085 Temperature and Pressure Sensor
DuinoMite web server made by hacking of newtork card
DuinoMite with serial printer
Mortgage Calculator
Lame attempt to play music with old Floppy
1-wire devices
SHIFTOUT command and LED matrix
GPS and DuinoMite
Posted: 10:55pm 01 Feb 2012
Wow, good post Olimex.
I like the knock sensor!
Olimex
Posted: 07:11pm 02 Feb 2012
Two new projects for today:
Humidity measurement with HS07
Capacitive Tank Fluid Level Metering
mookster1
Posted: 12:52am 03 Feb 2012
Floppy disk music? Incredible! Just imagine what you could do with a printer...
Capacitance is futile - roll on 2012!
djuqa
Posted: 01:04am 03 Feb 2012
Reminds me of the TRS-80 days making sounds by buzzing the TapeDeck control Relay
We all thought it was great until the relay crapped out.
VK4MU MicroController Units
Olimex
Posted: 06:35am 03 Feb 2012
DuinoMite - The French connection
DuinoMite playing the Nyan Cat meme
Click here to see the Project
Olimex
Posted: 06:28pm 06 Feb 2012
Using LED as light sensor
during the weekend I also made color sensor with just 4 LEDs: RED, GREEN, BLUE, WHITE and experiment to write code which to recognize what light you irradiate over the "sensors"
GREEN and BLUE are too close and can't be well separated but I will work some more this evening on the algorthm, hopefully tomorrow will post the Duinomite recognizes colors project
centrex
Posted: 07:47am 07 Feb 2012
Very interesting Olimex and I look forward to the results.
I suppose you are aware that leds have been used as the sensors for solar panel trackers for quite some time.
Cliff
Cliff
djuqa
Posted: 07:58am 07 Feb 2012
Great Idea;
Reminds me of the early days when you could scrape some black paint of the OC71 Transistor to use as a optotransistor or as a light Sensor.
Tavetan, have done any experimenting on SMD led's
Olimex
Posted: 09:27am 07 Feb 2012
any LEDs will do the job, the more bright the LED is more sensitive it is also
also the sensiticity decrease in this order
RED->GREEN->BLUE->WHITE
red LEDs for some reason are most sensitive and respond to any light source.
all LEDs obviously respond to White light but with different sensitivity
Baan BaaT
Posted: 08:59pm 09 Feb 2012
Hello Tsevtan,
I am very impressed with the experiments that you are carrying out especially the
mod-gsm development. My question, is there a similar board available that will be suitable to operate on the Australian 3G network. I ask this because the GSM network doesn't work in rural or remote areas where 3G is often available.
Many thanks,
Tim.
Olimex
Posted: 09:34pm 09 Feb 2012
Hi Tim,
there are 3G modules but they are very new and expensive
we have at the moment MOD-GSM-EDGE which is 236kbps
Tsvetan
Posted: 09:51pm 09 Feb 2012
  Olimex said   any LEDs will do the job, the more bright the LED is more sensitive it is also
Tsvetan,
Are you using CLEAR LENS LEDs?
