Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (dm) period, frequency input
herbnz
Posted: 07:53am 26 Jan 2012
Hi
I have been using the count input to measure a flow turbine. Decided to try Period works ok, period seems to be in millisec .
One question I do have is the reading is only interger numbers, can one switch to read the fractional part. The same applies to frequency .
Of course the count has to be whole numbers, hence the reason I thought I would try Period.
Herb
Edit was a mistake in original above count is 34 for 10 sec so 3.4 1 sec therfore 290 milsec correctEdited by herbnz 2012-01-27
