Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Keyboard Italian
shsjk59456
Posted: 09:26pm 24 Jan 2012
I use the PS / 2 keyboard works fine Italian only the keys are incorrect, you can change the font?
aargee
Posted: 09:36pm 24 Jan 2012
I think you're asking for the keyboard decoding to be remapped to suit an Italian keyboard and/or a font set to match.
I think this might be a bit difficult for a few requests, but you should contact Geoff with your request, using the e-mail link at the bottom of this page.
shsjk59456
Posted: 03:34pm 30 Jan 2012
  shsjk59456 said   I use the PS / 2 keyboard works fine Italian only the keys are incorrect, you can change the font?
I solved with the new version MMbasic 3.1 that supports the keyboard very similar to German Italian
darthmite
Posted: 07:38pm 30 Jan 2012
Hi ,
I integrate the German and French KB for the MM.
Actually i asked Geoff if it's OK for integrate the Italian Model.
This take some Flash memory away from the PIC32 and if it's worth
Geoff will probably give me a OK to made it too ...
Wait and see
I just hope that it will not people from 100 country with different kb layout
who want that i fill the precious PIC32 flash
Cheers.
Darth.
Posted: 10:53pm 30 Jan 2012
  darthmite said   Actually i asked Geoff if it's OK for integrate the Italian Model.
I seem to have lost your email (sorry).
Pleas add it in. I will have to modify the selecting function GetFlashOption(&KeyboardOption) to allow for more than three selections so just use a constant for the time being.
Don't worry about the amount of flash memory, we can always reduce the amount used by the internal flash drive if we need to.
darthmite
Posted: 08:43am 31 Jan 2012
Hi ,
OK mate , i start this evening
Cheer.
Darth.
shsjk59456
Posted: 01:56pm 31 Jan 2012
  darthmite said   Hi ,
Wait and see
Cheers.
Darth.
In fact it would be useful to include in the file AUTORUN.BAS the ability to bind some keys of KB to different font, as in the old DOS!
Thanks, Ciao
Posted: 09:11am 03 Feb 2012
Thanks to Darthmite MMBasic now supports the Italian keyboard.
All three versions (Maximite, DuinoMite and UBW32) of MMBasic 3.1B are attached.
2012-02-03_190612_MMBasic_3.1B.zip
To select the Italian keyboard use the command CONFIG KEYBOARD IT
There is little point in everyone updating as, other than the new keyboard support, there is little difference between this and 3.1.
Juri74
Posted: 12:53pm 06 Feb 2012
A little idea could be to have keyboard layout files on sd/internal drive and then load into memory the specific selected file when power up or with command CONFIG KEYBOARD XX where "XX" is the country code (US, UK, IT, FR etc..)
this could reduce the memory used and increase the memory space for internal disk or, at least, more memory for firmware.. almost all keyboard layouts in the world can be used without worry about memory limits..Edited by Juri74 2012-02-07
