Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update
Posted: 03:45am 21 Jan 2012
I have released an update to MM Edit.
The most obvious changes were to suit the changes in MM Basic V3 but I have retained compatibility with earlier versions and (I hope) MMBasic on Duinomite.
You can still work with or without line numbers and convert between the two forms.
For those who haven't tried MM Edit, it is a Windows application that lets you do your editing in the comfort of you own PC and relatively easily transfer file to and from the Maximite/Duinomite.
MM Edit is available from:
http://www.c-com.com.au/MMedit.htm
djuqa
Posted: 04:06am 21 Jan 2012
Added a Promo and link to latest version to Maximite.com.au & DuinoMite.com.auEdited by djuqa 2012-01-22
VK4MU MicroController Units
centrex
Posted: 06:25am 21 Jan 2012
Excellant work Jim
How do find the CGMMSTICK.
Cliff
Cliff
