Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : JPEG picture
teun
Posted: 07:43am 17 Jan 2012
Hi iam new here and new with MM basic. I did order some prints by Olimex and they are realy looking great. I was wondering would it be possible to display a picture wich is stored on the SD card for a few seconds before running a program? Or somewhere in the running program?
I hope my Englisch is good enough.
Thanks in advance from Holland.
Olimex
Posted: 07:53am 17 Jan 2012
JPEG decompression require lot of memory and BASIC will not handle it
but you can display BMP picture check this http://www.thebackshed.com/forum/forum_posts.asp?TID=4566&PN =1
jwettroth
Posted: 03:51pm 17 Jan 2012
JPEG decompression is too much for Basic but I was surprised to see that it really doesn't take that much memory or code to implment. I was surprised to see the following library, TcJpgDec poosted last year (see below). It seems like its not too far out for the hardware platform of MM though someone would have to link it in to the source, etc.
One of my hacker heroes, Chan (http://www.elm-chan.org) has posted a JPEG decompressor on his great web site. Its written in C. It can fit in 4.5k of code space and needs 3K of RAM. It runs on 8 bit class CPU's, proably would be very comfortable on a PIC32! MM Color isn't here yet so the utility of it isn't clear, I guess you could look at B&W snaps, etc.
Here are some specs-
TJpgDec is a generic JPEG image decompressor module that highly optimized for small embedded systems. It works with very low memory consumption so that it can be incorporated into tiny microcontrollers, such as AVR, 8051, PIC, Z80, Cortex-M0 and etc.
Features
•Platform independent. Written in ANSI-C.
•Easy to use master mode operation.
•Fully re-entrant architecture.
•Very small memory footprint:
◦3K bytes of RAM for work area. Independent of image dimensions.
◦4.5-9.5K bytes of ROM for text and constants.
•Output format: ◦Scaling ratio: 1/1, 1/2, 1/4 or 1/8 selectable on decompression.
◦RGB format: RGB888 or RGB565 pre-configurable.
John Wettroth
Olimex
Posted: 03:57pm 17 Jan 2012
what happened to Chan?
his web seems to be down, I also enjoyed his projects
jwettroth
Posted: 06:29pm 17 Jan 2012
Sorry- I inserted a www in the link- the proper link is:
http://elm-chan.org/
Alive and well and doing amazing things still...
John Wettroth
