Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (Mini-M) Power Supply
MM_Wombat
Posted: 12:17am 13 Jan 2012
If I supply the +5V to the minimite on the header pin, does it convert it down to 3.3V for the pic32 or do I need to supply 3.3V as well?
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
djuqa
Posted: 01:05am 13 Jan 2012
IC2 LM1117 is the 3.3v Regulator that creates the 3.3v feed to PIC32 from the 5v Rail
on original Maximite
On the Mini you have to supply 3.3v from external source
(use a small circuit based on the section around the IC2 from original circuit)
[quote=from description on geoffg.net.] CON2 pin 1 is the ground.
CON2 pin 2 is the power supply. The mini Maximite needs between 2.3 and 2.6V to operate and it draws about 125mA unloaded. When writing to the internal flash memory (drive A: in MMBasic) it needs a minimum of 2.9V.
CON1 pin 2 is the 5V supply from the USB if it is connected to a host computer. If you want to use this to power the mini Maximite you will have to provide an external low dropout 3.3V regulator and feed its output to CON2 pin 2.
[/quote]Edited by djuqa 2012-01-14
VK4MU MicroController Units
MM_Wombat
Posted: 03:23am 13 Jan 2012
Thanks.
