Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM and the HH10D
palcal
Posted: 10:43pm 08 Jan 2012
Yes me again with another problem. I have a humidity sensor which gives out a frequency depending on humidity. I have it connected to pin 11. With no program in memory if I type into the keyboard;
SETPIN 11,3
PRINT PIN(11)
it gives me the frequency in Hz.
However if I write a two line program;
10 SETPIN 11,3
20 PRINT PIN(11)
RUN
it gives me a zero
Anyone know what I am doing wrong.
Paul.
Posted: 10:47pm 08 Jan 2012
At a guess, not giving it time? Delay a little between the lines?
CircuitGizmos
Posted: 11:40pm 08 Jan 2012
That should be it. In order to measure a frequency, you have to give the MM a chance to measure that frequency. I would suggest:
10 SETPIN 11,3
15 PAUSE 2000
20 PRINT PIN(11)
RUN
seco61
Posted: 11:58pm 08 Jan 2012
Hi Paul.
See the code that was posted in your original HH10D post.
Remember that the MMBasic code will execute approximately 30000 lines of code a second. The HH10D will have an output frequency of around 5 - 10kHz. In the time that MMBasic has executed 2 lines of code you will see a value of 0 or 1 returned. For an accurate frequency measurement you will need to wait at least a second between readings, and between setting the pin to frequency measurement and using the value.
Gerard (vk3cg/vk3grs)
palcal
Posted: 12:13am 09 Jan 2012
Thanks all, I now remember seeing that somewhere, problem solved.
Paul.
