Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM - EDIT mode
palcal
Posted: 01:12am 08 Jan 2012
Re MM basic. Yes I wasn't in edit mode, but now I have another problem.
When using MMIDE and connected to MM when I type 'EDIT' it simply stops responding and I have to terminate. I tried using Terra Term and EDIT seems to work OK until I try to paste my program, the window with the clipboard appears but when I click OK only four random lines of program appear. If I paste a program with line nos. while not in edit mode it works fine.
I was having a great time with the MM until now, hope I can overcome these problems.
Sorry to be such a nuisance.
Paul.
centrex
Posted: 02:18am 08 Jan 2012
Hi Palcal
I may be wrong, are you using the latest ver3 of MM Basic if so it should come up with an on screen editor when you type EDIT.
If you are using MMIDE you would edit the program in the MMIDE Basic window and then copy it to the Maximite to run.
Another thought are you using the MM in vga mode or composite as there is a problem with edit in composite.
Hope this is of some help.
Cliff Edited by centrex 2012-01-09
Cliff
palcal
Posted: 02:55am 08 Jan 2012
Thanks. I went back to using a monitor and keyboard. I transferred the file to the SD card on my laptop. Everything works fine, just can't do it using Tera Term. Will try MMIDE again later.
Many Thanks to all who have helped.
Paul.
CircuitGizmos
Posted: 03:03am 08 Jan 2012
MMBasic 3.0 firmware was released and MMIDE has yet to fully support the edit mode.
Not the fault of MMBasic 3.0. I have to update MMIDE to support the edit mode.
Posted: 04:56am 09 Jan 2012
  palcal said   I tried using Terra Term and EDIT seems to work OK until I try to paste my program, the window with the clipboard appears but when I click OK only four random lines of program appear. If I paste a program with line nos. while not in edit mode it works fine.
Paul.
To paste code into the EDIT window, you need to have big delays between lines.
I have used TeraTerm with a character delay of 1mses/char and a line delay of 300mses/line.
Slow but sure....
The full screen editor has a lot to do.
Jim.
