Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : re MM Basic
palcal
Posted: 10:09pm 07 Jan 2012
I tried just writing a simple for next loop without line nos. and it gives me error message 'for without next' and 'next without for'. as soon as I add the line nos. everything is OK.
I line numbered my complete program and it runs OK but remove the line nos. and use labels and it won't work.
I'm sure I am writing it OK as I have written many programs for the PICAXE.
Maybe I will try downloading and installing V.3 again incase it has an error.
Paul.
djuqa
Posted: 10:12pm 07 Jan 2012
Show us the Code version without line numbers please.
VK4MU MicroController Units
Posted: 10:26pm 07 Jan 2012
I think I know the problem.
In version 3, when entering new code without line numbers, you must be in EDIT mode. That tells MMBasic you are editing a program, otherwise it will try to run each line as you enter it. Just type EDIT to start the editor.
elproducts
Posted: 10:49pm 07 Jan 2012
I'm sure your right Gizmo.
With 3.0 you either write the old fashion way with line numbers
or
type EDIT first and then work from within the built in editor.
It's two styles of retro computer in one.
www.elproducts.com
jebz
Posted: 11:27pm 07 Jan 2012
  palcal said   I tried just writing a simple for next loop without line nos. and it gives me error message 'for without next' and 'next without for'. as soon as I add the line nos. everything is OK.
There is a bug that may be producing the problem you're encountering -
If you have an odd number of blank lines before a NEXT, ENDIF, DATA, WHILE or WEND statement you will get an error message. MM Bug list
palcal
Posted: 12:26am 08 Jan 2012
OK I wasn't in EDIT mode, I will go and try that.
Thanks All
Paul.
