Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMIDE Launch
elchucko
Posted: 09:24pm 01 Jan 2012
Hi, When I start the MMIDE utility it takes about 30 seconds before I see the MMIDE display. When selecting the com port it takes another 6 seconds to recognize the port. Then I can use the application. Is there a new release?
CircuitGizmos
Posted: 10:59pm 01 Jan 2012
Is this the 2.0 version that does this? The version is in the title bar.
elchucko
Posted: 06:39pm 02 Jan 2012
The program build date is 2011-11-21. I don't see what you're pointing to?
CircuitGizmos
Posted: 07:18pm 02 Jan 2012
Download 2.0 and give it a try. I just posted about it in another thread.
Click here:
MMIDE 2.0
elchucko
Posted: 07:53pm 02 Jan 2012
Hi, MMIDE 2.0 takes 40 sec to load and 10 sec to select a different port.
CircuitGizmos
Posted: 08:12pm 02 Jan 2012
  elchucko said   Hi, MMIDE 2.0 takes 40 sec to load and 10 sec to select a different port.
I'm really not sure what approach to take to solve this for you. In my machine it is about 5 seconds to start up. I'm running a Win7 64 at 2.8 gig with 8 Gig RAM. My development machine. I would imagine that other machines perform differently, but the program is small compared to other applications.
elchucko
Posted: 08:24pm 02 Jan 2012
I have an HP desktop, 3.3 ghz, 8mb memory (W7) and an HP laptop(Vista). Both exhibit the same problem as described.
donmck
Posted: 09:05pm 02 Jan 2012
  elchucko said   I have an HP desktop, 3.3 ghz, 8mb memory (W7) and an HP laptop(Vista). Both exhibit the same problem as described.
I didn't get a chance to try MMIDE2 on a decent PC, as I am now stuck in Darwin with an EEEPC Intel Atom N270 1.6g and a DM-mini to try it on.
I feel the EEEPC hasn't got enough grunt to do much, as I can't fully load a program with MMIDE, MMIDE2, or TerraTerm. It locks up after about two lines of code.
But on this notebook, MMIDE loads in a second, and MMIDE2 in about 3 seconds.
With MMIDE2, I was able to toggle the mini's green LED via Rob's menu system.
When I get back, I'll try MMIDE2 on a decent system.
Cheers Don...
https://www.dontronics.com
CircuitGizmos
Posted: 10:07pm 02 Jan 2012
Thanks, Don. I wish it worked better for you on the EEE.
I just ran it on an underpowered Win2000 and it was faster then on my development PC.
elchucko: Are you running a virus program that scans executable programs before they are run?
elchucko
Posted: 11:12pm 02 Jan 2012
Hi, I don't have any virus pgm scanning on either PC. I have Norton on one PC and System Suite on the other.
