Local Time 03:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (MM) CONTINUE not working
pcaffalldavis
Posted: 01:22am 27 Dec 2011
I’m using MM BASIC in version 2.7B and the CONTINUE command does not seem to work for me. Sure would be nice if it did. When I get an error code, or set up a stop in the processing I often need to turn TRON on and continue from that point. I often need to check variables at such a point and go on from there but can’t since CONTINUE does not seem to work.
Does anyone have any suggestions or know why it is not working?
Pete in Hyder
We're all here 'cause we're not all there.
MM_Wombat
Posted: 10:31am 28 Dec 2011
I found that the
OPTION error CONTINUE
only works for SD card errors. It did not catch the "out of memory" errors my program generates.
I do have it catching the sd card errors though.
2075 LOCATE 270,20 : INPUT "Filename to Save : ",savename$
2080 IF (RIGHT$(savename$,3)<>"fnt") THEN savename$=savename$+".fnt"
2090 OPEN savename$ FOR output AS #1
2100 typefile$="save"
2110 ON MM.ERRNO GOTO 3350,3410,3470,3530,3590,3650
3350 'ERROR -No SD Card present
3410 'Card is Write Protected
3470 'not enough space
3530 'All root dir. taken
3590 'Invalid Filename
3650 'Cannot find File
at the end of all these errors i check for save or load, then jump to a line in that routine 2075(save) or xxxx(load)
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
