Local Time 21:46 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C AND MMBASIC
ratsac
Posted: 08:59pm 19 Dec 2011
Hi just new to this forum and to maximite Computers
Can anyone assit or redirect me in the use of I2C procol
I am using mmbasic and a PCF8574 (8* i/o device).
The commands I have used are
I2CEN 10,100 (enables i2c )
I2CSEND 64,0,1,0 (should set ports to low)
Doesn’t work I know about using the negitive –330 ohm resister –pcf8574
Has anyone had success with any I2C devices and mmbasic
DuinoMiteMegaAn
Posted: 09:25pm 19 Dec 2011
RTC I2C "write" code snippet (courtesy of Ken)
720 REM I2CSEND i2caddr, 0, 1 , &h0
725 I2CSEND i2caddr, 0, 10, 0, 0, 0, seconds, minutes, hours, day, rtcwday, month, year
730 I2CDIS
770 ? "0=ok 1=nack 2=timeout"; MM.I2C <------ observe this code !!!!
Another I2C "write" code snippet
460 ' Write Time to RTC
470 i2caddr = &h68 ' DS3231 I2C address
480 I2CEN 400,100 ' Enable I2C <--- high speed 100 ms timeout
490 I2CSEND i2caddr, 0, 8, &h0, seconds, minutes, hours, rtcwday, day, month, year
500 I2CDIS
Only 10 KHz ? For I2C speed?
Make sure you got the proper pullups for the I2C ??? You need two of them.
See the Maximite manual.
Is this I2C device a 3.3 VDC device or a I2C 5 VDC device? Make sure the pullups
are tied to the same device VCC
Edited by DuinoMiteMegaAn 2011-12-21
Olimex
Posted: 09:47pm 19 Dec 2011
if A0,A1,A2 are wired to ground try:
I2CSEND 32,0,1,0
ratsac
Posted: 09:52pm 20 Dec 2011
Thanks For assistance
Have tried addresses 64 end 32 with no success repower pcf8574 with own +5v
but alas still no success even raised speed and shorten bus
will look for a logic alternative.javascript:AddSmileyIcon('')
DuinoMiteMegaAn
Posted: 12:54am 21 Dec 2011
What are you using for pullups?
Put this line of code after writing to your device.
? "0=ok 1=nack 2=timeout"; MM.I2C '<------ observe this code !!!!
And tell me what you got?Edited by DuinoMiteMegaAn 2011-12-22
ratsac
Posted: 03:18am 21 Dec 2011
Have tried adding mm.i2c
10 I2CEN 100,300
20 I2CSEND 64,0,1,0 (ALSO 32 TRIED)
30 I2CDIS
40 ? "0=OK 1=NACK 2=TIMEOUT";MM.I2C
THE RESULTS ARE ALWAYS THE SAME 0 0 2 0 2 0 2
EVEN IF I DISC I2C PORTS NO CHANGE
NIL COMMUNICATIONS RESULT
THE BOARD HAS 3 * 10KOHM PULLUP RESISTORS MOUNTED O0N BOARD
RATSAC
Olimex
Posted: 05:53am 21 Dec 2011
64 is not correct address for this device
you have to remove the last R/W bit 0 from the address as it's add from MM-BASIC
Posted: 09:38am 21 Dec 2011
  ratsac said   Have tried adding mm.i2c
RATSAC
Are the three pullups connected to the address pins and V+?
If so try 39 as the address (32 + 7)
seco61
Posted: 09:18am 22 Dec 2011
Hi.
First I will assume that the PCF 8574 is correctly connected (common ground with the Maximite, A0 - A2 connected to ground, SDA connected to IO pin 12 and pulled high by a 2.7K resistor to the Vcc pin of the device, SCL connected to IO pin 13 and pulled high by a 2.7K resistor to the Vcc pin of the device).
The following code should set the output pins high, then read the state of the pins:
10 I2CEN 100,100
20 I2CSEND 32,0,1,&hff
30 ? "MM.I2C after send: "; MM.I2C
40 I2CRCV 32,0,1,port
50 ? "MM.I2C after recv: "; MM.I2C;", Data from port: ";HEX$(port)
60 I2CDIS
70 END
Please post the output if you are still having issues.
Gerard
Gerard (vk3cg/vk3grs)
ratsac
Posted: 02:25am 23 Feb 2012
have tried the above program the responses i received are
MM.I2C after send: 0
[4] 40 I2CRCV 32,0,1,port
Error: Receive variable not found
operates output in device ok
also is there any difference when using ubw32 as nil result is given
crackerjack
Posted: 02:56am 23 Feb 2012
You need to define port as an array with length as to what you receive to expect back from the i2c device.
So in the used example make line 5 something like this:
[code]
5 Dim RDBuff(5) ' length according to the response expected from your device
[/code]
From the manual:
[code]
I2CRCV addr, bus_hold, rcvlen, rcvbuf [,sendlen, senddata [,sendata ....]]
Receive data from the I2C slave device with the optional ability to send some data first.
'addr' is the slave i2c address (note that 10 bit addressing is not supported).
'option' is a number between 0 and 3
1 = keep control of the bus after the command (a stop condition will not
be sent at the completion of the command)
2 = treat the address as a 10 bit address
3 = combine 1 and 2 (hold the bus and use 10 bit addresses).
'rcvlen' is the number of bytes to receive.
'rcvbuf' is the variable to receive the data - this is a one dimensional array or if rcvlen is 1 then this may be a normal variable. The array subscript does not have to be zero and will be honoured; also bounds checking is performed.
Optionally you can specify data to be sent first using 'sendlen' and 'senddat'. These parameters are used the same as in the I2CSEND command (ie, senddata can be a constant, an array or a string variable).
Examples:
I2CRCV &h6f, 1, 1, avar
I2CRCV &h6f, 1, 5, anarray(0)
I2CRCV &h6f, 1, 4, anarray(2), 3, &h12, &h34, &h89 I2CRCV &h6f, 1, 3, anarray(0), 4, anotherarray(0)
The automatic variable MM.I2C will hold the result of the transaction.
[/code]
Edited by crackerjack 2012-02-24
ratsac
Posted: 04:32am 27 Feb 2012
THANKS FOR ALL YOUR VALUABLE ASSISTANCE
SAC
