Forum Index : Microcontroller and PC projects : (MM/DM) Tera Term keyboard, End/Home keys
yobortsa
Posted: 11:13pm 16 Dec 2011
Hi all,
I got sick of the Home and End keys not working in Tera Term on the Maximite, so I created a keyboard mapping file for the Maximite.
Feel free to use if it helps - attached in a ZIP file. In Tera Term menu:
Setup | Load key map...
Browse to the file and select. Unfortunately it doesn't seem to remember this setting if you 'Save setup...' in the menu, so each session you need to reload the keyboard mapping. Anybody know how to make this stick?
This file is based on IBMKEYB.CNF from Tera Term Pro v2.3 and modified to support Home/End/Insert keys with the Maximite.
David
2011-12-17_090613_maximite.zip
