Local Time 03:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Linux Mint 12
elchucko
Posted: 06:18am 16 Dec 2011
Any Linux user that has their MM connected? Drivers available? Thank you
Olimex
Posted: 06:29am 16 Dec 2011
Hi, in our users manual is covered how to work in Linux with MM/DM
Posted: 02:14pm 16 Dec 2011
I'm not on Mint but all the drivers needed were already there and probably are for Mint, too. Post what fails, if anything
elchucko
Posted: 02:45pm 16 Dec 2011
When I plug in my usb cable the PC/Linux Mint does not recognize MM is there. I'll check user manual. Thank you
elchucko
Posted: 03:25pm 16 Dec 2011
The only reference I see in the user manual is a Windows driver that's needed. Since I'm new at Linux I don't know how to compare Linux and Windows for driver requirements.
elchucko
Posted: 06:47pm 16 Dec 2011
I see no reference to Linux in the MM user manual that's on Geoff's web site. :(
Posted: 09:25pm 16 Dec 2011
You need the DuinoMite manual.
Posted: 04:19pm 17 Dec 2011
elchucko, first check dmesg before and after you plug the board in. You should see it recognised.
Then I guess you need to know more about the MM. (The DM works as expected.)
I only have a DM. It appears as 1 of 2 devices:
1 when in bootloader mode
another when not in that mode
in case that helps.
Generally Windows needs drivers but Linux commonly has them available already. Don't assume Linux behaves the same as Windows!!
elchucko
Posted: 06:05pm 17 Dec 2011
Now I'll really show my lack of knowledge. What is "dmesg"? I don't see any response from Linux when I plug the usb cable to the PC. Furthermore, what utility is available (such as Tera Term) to utilize the MM? Thank you
Olimex
Posted: 11:32pm 17 Dec 2011
try googling dmesg
http://en.wikipedia.org/wiki/Dmesg
as it show lot of driver info you can type at command prompt "dmesg | grep tty* " before and after you plug your board
in DM user manual is written how to use minicom
