Forum Index : Microcontroller and PC projects : (UBW32) firmware
Gadget
Posted: 05:45am 16 Dec 2011
Has anyone loaded the firmware into the UBW?
if so any issues
I read in the bug list on Geoffs site there is an issue with the writing to sd card with the UBW32.
Terry
aargee
Posted: 07:07am 16 Dec 2011
Yes I have, it works fine.
Use V2.7B firmware if you want the SD card to work correctly. Be aware that using the SD card circuit in the manual, the SD LED indicator inverted - i.e blanks when there is SD activity, so you should be able to just invert the LED which I haven't done.
- Rob.
Edited by aargee 2011-12-17
