Forum Index : Microcontroller and PC projects : (MM/DM) Navman Jupiter 21 GPS module
yobortsa
Posted: 02:38am 13 Dec 2011
I have a Navman Jupiter 21 GPS module hooked up to a Maximite SM1 but I'm not getting time or a position out of the unit. Does it need to be initialized somehow? It uses the SiRFstarIIe/LP chipset. This is all I get out of the unit (even after running for 45mins):
$GPGSV
$GPRMC
$PRWIZCH
$GPGGA
$GPGSA
$GPRMC
$PRWIZCH
$GPGGA
$GPGSA
$GPGSV
$GPGSV
$GPGSV
$GPRMC
$PRWIZCH
$GPGGA
$GPGSA
$GPRMC
$PRWIZCH
$GPGGA
$GPGSA
$GPGSV
$GPGSV
$GPGSV
David
yobortsa
Posted: 03:13am 13 Dec 2011
Solved - it was my code. The INPUT #1 statement only gets the characters up to the first comma.
Doesn't work:
10 OPEN "COM1:4800" AS #1
20 a$ = ""
30 INPUT #1, a$
40 PRINT a$
50 GOTO 20
Does work:
20 a$ = ""
30 a$ = INPUT$(1,1)
40 PRINT a$;
50 GOTO 20
