Local Time 03:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) Help File and firmware upgrade
Bryan1
Posted: 07:26am 10 Dec 2011
G'day Guy's,
Hi Guy's,
Over the last week or so I have been testing out the new help file system with Ken's new firmware. Today I added a heap more to the file like SPI I2C etc.
The link to the new firmware for is at:-
http://www.kenseglerdesigns.com/cms/forums/viewtopic.php?f=4 &t=2
and
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Hardware%2FDontronics%2FOlimex%2FDownload+Files%2F
Don will also host the 'help' file folder too and I'll let Don provide that link.
OK
So far there is 122 text files that I have written and on the main 'help' page is all the details for adding an option to invoke F1 to start the help file.
All one needs to do to start up a help is type help "whatever
Then the file will clear the screen and show, now a Ken suggested this text based system if one is working on a program and need's to look at a help file the program you are working on won't be shutdown so it does give a very handy reference.
All the data for this help file system was taken from the MM V2.7 manual and the current Olimex pdf manual. So many thanks to both parties for providing the base of this project.
Right now all of that is out of the way........
This Help File system is Totally Open Source so users are encouraged to add content and edit the text files if you think the page could look better. One thing I would like is code examples for each command so when either new or experienced users get stuck on a command they can have a quick reference then get back on track.
Also another great feature this new system can provide is a 'post it note' style system. Lets say you have a code snippet or something else you want to reference just make a text file and using the help "whatever... it will be shown.
I would for this thread to be a base for any new items to place in new help system and just attach a zip file of the whole new folder and the separate files that you have done so user's can decide if they want the new update.
Guy's this is my first project in the Duinomite and I thought well if it will be good for me then why shouldn't everyone have the benefit of it. After All the spirit of Open Source is alive with this whole Duinomite project so lets make this new help file even better so everybody has a great online reference when needed.
Regards Bryan
P.S. I'm sure if Geoff wants to include this for the Maximite I'm sure Ken will give a hand so the Maximite users can also benefit.
donmck
Posted: 10:02am 10 Dec 2011
My Help link is at:
http://tinyurl.com/83ro963
Cheers Don...
https://www.dontronics.com
DuinoMiteMegaAn
Posted: 10:19am 10 Dec 2011
@Bryan1
I hope you fixed all the spelling errors in the command basic files.
Last week, I combined all your files into one document and found many spelling mistakes.
You could use my PDF file to reproduce all your basic command files again.
I only ran one pass on the spelling checker, so I advise you to double check
for any errors again. After all, your help files would be used by everyone in
the community and having the spelling errors fixed would make it professional.
I took Bryan's1 "help" MMBasic code help snippets and converted them to a PDF using the free OpenOffice 3.0 word application.
I sorted all the help code snippets in alphabetical order and put one basic code snippet per one PDF page except for the long ones.
A spell checker was applied to fix all the obvious spelling errors. (Brian used Sparkey's spell checker and there were a lot of spelling errors)
From this PDF document, you can easily "copy and paste" the basic code help snippets, if need be. I used them as a reference tool.
Also, I included CrackerJack's quick MMBasic reference.
Enjoy
The attached PDF is the document "Bryan1_Code_Help_Snippets_R1.PDF"
2011-12-04_133735_Bryan1_Code_Help_Snippets_R1.pdf
The attached zip file contains the source document OpenOffice "odt" file for user additions, deletions and corrections
and to generate another PDF file.
2011-12-04_133811_Bryan1_Code_Help_Snippets_R1.zip
Back to Top
Edited by DuinoMiteMegaAn 2011-12-11
Olimex
Posted: 01:06pm 10 Dec 2011
Well done Bryan. sure it may have spelling errors, but it's still nice idea and well implemented. Recently when I wrote some code example I had to check again and again with the user manual for the I2C and SPI command syntax, if I had this help file installed it would save me some time.
I'm sending you one DuinoMite badge:
note these are new and are not for sale, the only way to have one is to make nice contribution for DuinoMite community, you got the first one for the Help system.
DuinoMiteMegaAn
Posted: 02:01pm 10 Dec 2011
There should be no excuse for spelling errors unless you are Sparkey.
Free Sparkey
donmck
Posted: 06:19pm 10 Dec 2011
  Olimex said   Well done Bryan. sure it may have spelling errors, but it's still nice idea and well implemented. Recently when I wrote some code example I had to check again and again with the user manual for the I2C and SPI command syntax, if I had this help file installed it would save me some time.
Sorry, couldn't help myself Tsvetan.
Badges, Badges, we don't need no stinkin badges!
http://www.youtube.com/watch?v=nsdZKCh6RsU
http://www.youtube.com/watch?v=gx6TBrfCW54&NR=1&feature=ends creen
http://www.youtube.com/watch?v=-lj056ao6GE
http://www.rudebadmood.com/badges/mov.php?mov=hammer-snip.mo v
It is one of the most famous and re-worked lines in movie history, and I was
constantly reminded of it by an old work friend, who is still alive today, would be
close to 90 years of age. We always had a chuckle when he went into his
stinkin badges routine.
Mick also used the routine on me in the last week or two.
Apart from the little sidestep into movie history, I think it is a grand idea.
A stinkin Dynamite badge already!!!
Cheers Don...Edited by donmck 2011-12-12
erg322
Posted: 07:33pm 10 Dec 2011
Marvelous stuff!!!
Woke up this morning to some really neat software.
(In no apparent order)
Many thanks Ken for the hooks and tweaks in the Duino's "DEC 9" MMBasic.
Many thanks Bryan for working on all those entries in the Help file. I'm a cloth-head at times and it's great you went the extra mile and included working examples.
***Ever always, Geoff for creating MMBasic in the first place.
ksdesigns
Posted: 12:22am 12 Dec 2011
New beta version posted Dec-11-2011
ken
RTC On Boot now works you can select PCF8563 or DS1307<- not tested only PCF8563
so all you need to do now is set the time and date
time$="10:20:00
date$="11/12/2011
and it will update the RTC after any changes to time$ and date$
added dow day of week
print dow '0-sunday 1-monday ect ..
also moved all timekeeping to the pic32 internal RTCC so you will not lose time when you write or read drive A:
added new menu option Show Time Date that will display the date and time at boot
Maximite BASIC Version 2.7ASettings
Copyright 2011 Geoff Graham
Sunday December 11 2011 12:03:32
B:\>
DuinoMite Setup Menu - V1.3 Dec 11 2011
Hardware Platform - DuinoMite
V) Video Mode - NTSC - 480
R) RTC On Boot - PCF8563
D) Date Format - MM/DD/YY
T) Show Time Date - Enabled
S) SD Card - Enabled
U) Usb Console - Disabled
C) Serial Console - Com3:
B) Baud Rate - 115200
M) Custom Video Mode
P) Print Custom Video Mode
Q) Quit Dont Save Settings
X) Exit Save Settings
DuinoMiteMegaAn
Posted: 02:03am 12 Dec 2011
Be careful what numbers you use for the days of the week!
You see DS1307/DS3231 uses 1-7 and Sunday being 1.
You need to have both the PIC32 RTC and the battery protected RTC
have the same day value. That way you could refresh both RTC
clocks with the same value.
Please note: The PIC32 RTC does not have a DOW (Day of week) but
it can be easily computed. See my precision time keeping link:
BTW ... The PCF8563 uses 0-7 and Sunday = 0 Edited by DuinoMiteMegaAn 2011-12-13
ksdesigns
Posted: 02:39am 12 Dec 2011
thats good to know i dont have any ds1307's to test really
but its easy to fix ..
the PIC32 RTC does have day of week it does not calculate it from the start you have to tell it when to start after that it keeps track of it .
Register 29-4: RTCDATE: RTC Date Value Register(1)
2-0 WDAY01<2:0>: Binary-Coded Decimal Value of Weekdays bits,1 digit; contains a value from 0 to 6
ken
DuinoMiteMegaAn
Posted: 03:38am 12 Dec 2011
@Ken
Just curious, why two releases 2 days apart?
ksdesigns
Posted: 03:45am 12 Dec 2011
Free Time :)
ken
Posted: 06:19am 12 Dec 2011
  ksdesigns said   Free Time :)
ken
Where do you get that?
I want some...
DuinoMiteMegaAn
Posted: 03:33pm 12 Dec 2011
@Ken
Please, with each release of any "new updated firmware" state
what has been changed and any known outstanding issues and
bug reports. In fact, have a revision history so users would
able to track the firmware revisions and any known issues.
ksdesigns
Posted: 06:41pm 12 Dec 2011
ken
I want some...
It's easy spend 10 years working for a company building great products
that the Chinese steal and sell it back to your parent Company for
1/10 of the price .
All that equals long vacation :)
ken
Bryan1
Posted: 12:53am 17 Dec 2011
Bumped for Snowwy
