Local Time 03:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mini maximite eagle file
devigan
Posted: 11:53am 08 Dec 2011
Hi, just wandering if anyone can pass me the eagle file on mini maximite like to modify for my project
Olimex
Posted: 05:58am 09 Dec 2011
you can download the DuinoMite Eagle schematics and modify them, note the CC licensee
if you use them you should release your work with the same terms
MaxiMite hardware is not completely open source as only picture of the schematic is available, and to the best of my knowledge the Maximite software is closed source from version 2.7A
devigan
Posted: 03:11am 10 Dec 2011
Ray B
Posted: 08:48am 10 Dec 2011
I'm in Sydney until early next week but when I return to Perth where my main PC is I'll post the eagle schematic & PCB layout for a I/O extender card I've designed for the 26 pin MM connector.
I may also have some original MM schematic & PCB files.
With these files you will be well on the way to duplicating most of the minimite parts. When you get these files & components make up a eagle maximite library of components.
Look for my post maybe next Tuesday / Wednesday
RayB from Perth WA
devigan
Posted: 02:31am 11 Dec 2011
Sounds good
Ray B
Posted: 02:29am 13 Dec 2011
Attached are the following Eagle files:
Original MM Schematic & PCB files
My Maximite I/O schematic & PCB - all looks OK but yet to get around to building board.
2011-12-13_122853_Eagle_Schematic_&_PCB_Files.zip
Enjoy & please share on the forum any work you produce
RayB from Perth WA
devigan
Posted: 01:08pm 21 Dec 2011
Thanks Ray
