Local Time 03:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Serial port buffer size
AndrewB
Posted: 12:35am 04 Dec 2011
Quick question - when setting up MM serial ports 1 or 2, the buffer size can be set to a number whose limits I've not really tried, but have set to 4096 with no error message. However, on reading, it seems possible to read only up to 255 characters at a time, so if more characters are in the buffer, you have to do repeat reads until the buffer is empty.
Is this correct, or am I missing something?
Example Code 1:
open "com1:4800, 4096" as #1
print input$(255, #1)
In this case, screen output is first 255 characters in the com1 input buffer
Example Code 2:
print input$(256, #1)
In this case, screen output is 'error: number out of bounds'Edited by AndrewB 2011-12-05
Olimex
Posted: 06:11am 04 Dec 2011
COM port buffers are 128 bytes long last time I check the sources
INPUT$ returns string, strings in MM-BASIC are 0..255 bytes long this is why you get error when you want to read bigger string
you can use LOC(#1) function which returns how many bytes are read in the buffer before you use INPUT$
Posted: 10:32pm 04 Dec 2011
From the Help file,
The default buffer size is 256 bytes for Tx and Rx
One example has a buffer of 1024 bytes.
I don't remember seeing the maximum size anywhere.
As already stated, the string size limit of 255 bytes was causing your error.
Using a big com port buffer size is likely to use up ram which might be needed elsewhere in your program.
AndrewB
Posted: 11:15pm 04 Dec 2011
Thanks guys.
It's a long time since I've programmed in Basic, and I had read many times 'Implementation Characteristics' paragraph in the MMBasic User Manual, but each time the maximum string length of 255 failed to sink in.
Yes, a long buffer length would be wasteful and in most cases be unnecessary, but I was just checking since I hadn't actually found a limit.
Thanks again.
Posted: 02:35am 05 Dec 2011
TassyJim is correct. The default buffer size is 256 bytes for both Tx and Rx. And, yes, if it is bigger than 255 bytes you will have to read it in a number of hunks. A bigger buffer is handy if your program occasionally becomes busy (writing to a LCD for example) and cannot regularly check the serial port for data,
The only limit to the buffer size is the amount of free memory in the string and array section (where the buffer is allocated).
For example, if you used: open "com1:4800, 4096" as #1 The memory command will report that an extra 8K of array and string memory was used. Incidentally, this part of memory will be renamed to "General Memory" in the next version because it is increasingly being used for more than just arrays and strings.
swoodgate
Posted: 05:45am 05 Dec 2011
Hey Geoff
"... bigger than 255 bytes you will have to read it in a number of hunks."
That's some good looking data you've got there!
Also wanted to say thanks for the Maximite, haven't had this much fun for ages, teaching programming concepts to my kids is so easy when you can show examples instantly on the screen.
Best regards
Steve
