Forum Index : Microcontroller and PC projects : (MM-DM) News from Sparkey
donmck![]() Guru Joined: 09/06/2011 Location: AustraliaPosts: 1314 |
(MM-DM) News from Sparkey If you have been on the TBS forum and this group for any length of time, you will know of Sparkey. He just popped in to pick up a MOD-IO for his new DuinoMite Mega. A few days ago, I gave him an early green proto Rev A DM-Mega, that pretty much worked, with the exception of the SD card, as there has been schematic changes since the Rev A. He loaded MM2.7a into the old DM-Mega and said it worked via a terminal program, and he was able to run basic programs. I was a little shocked that he had even thought of doing this, but decided to load up MM V2.7b into a Mega while he was here. Yes, it worked, even drive A: worked, but because of the hardware differences, we had no VGA, keyboard, or SD card, but we were able to run BASIC programs that didn't use any I/O, as the BASIC core of both the MM and the DM is the same. Yes the BASIC is 100% compatible, it is the hardware that is different. Cheers Don... https://www.dontronics.com |
| camfab Newbie Joined: 10/09/2011 Location: AustraliaPosts: 13 |
I personally think its a shame things went the way they did with sparky, he had alot of passion for the site ( too much at times ), lets hope that with time, a spellchecker and some "chill pills" we may see his colorful return. Dont get me wrong, his banning was completely his own doing and no-ones elses fault but hopefully he will have learnt from that, and have a place here again sometime. IMHO Dion Fre Sprky ///.../// |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
Yes now we need a version of the MMbasic that auto-detects the hardware and caters for the differences Geoffg / Ken how about it?. VK4MU MicroController Units |
| ksdesigns Senior Member Joined: 25/06/2011 Location: United StatesPosts: 143 |
We actually have that ability in the DuinoMite hardware just have not used it yet . Voltage divider on AN15 . ken |
I have started a NEW Topic as this issue really needs to be visible and debated VK4MU MicroController Units |
| ajkw Senior Member Joined: 29/06/2011 Location: AustraliaPosts: 290 |
Good to hear Sparkey is still 'Maximiting.' |
| vasi Guru Joined: 23/03/2007 Location: RomaniaPosts: 1697 |
Maybe a fast modification of firmware to suit Sparkey board? Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
I was hoping it was a suspension not ban. The speelign wos tuf 2 cope wiv n the lack of punc2ashun. |
| Talbit Senior Member Joined: 07/06/2011 Location: AustraliaPosts: 210 |
Seems I missed something. What happened to Sparkey? Talbit Talbit |
Worm![]() Newbie Joined: 30/06/2011 Location: New ZealandPosts: 38 |
Sparkey was a bad boy and had to be baned. I think there is going to be a few people who are going to miss him. Plus I feel we should call all spell checkers, The Sparkey spell checker, after the famous Sparkey. There's no such thing as a free lunch. |
Naughty Sparkey! What did he do that was so damaging, prey tell? I thought maybe he had zapped himself with one of his concoctions. I thought he was very entertaining. Talbit Talbit |
I think Sparkey might of had a flash back and posted some naughty comments and no, I dont think he zapped himself, but I could be wrong. There's no such thing as a free lunch. |
| rhamer Senior Member Joined: 06/06/2011 Location: AustraliaPosts: 174 |
I'm going to get some tshirts made. Fre Sprky ///.../// Let me know if anybody wants one. Cheers Rohan Btw I would like to see him back at some point. Rohan Hamer HAMFIELD Software & Hardware Solutions Makers of the Maximite Expander. http://www.hamfield.com.au |
Hi Rohan, yes I would like 2. I miss sparky as well. You can find him at http://www.kenseglerdesigns.com/cms/forums/ Kevin There's no such thing as a free lunch. |
Fre Sprky ///.../// hehe i've been searching for a witty signature! thanks rohan Fre Sprky ///.../// |
