Local Time 03:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) Bytes left drv A on DuinoMite Mega?
DuinoMiteMegaAn
Posted: 11:15pm 30 Nov 2011
(DM) Bytes left on drive A on DuinoMite Mega?
#1. How bytes are left on drive A on the DuinoMite Mega
using the standard factory release version 2.7 firmware?
I have 32,608 bytes left which seems very low?
Note: That is without any files saved on this drive!
Edited by DuinoMiteMegaAn 2011-12-02
donmck
Posted: 12:26am 01 Dec 2011
  DuinoMiteMegaAn said   (DM) Bytes left on drive A on DuinoMite Mega?
Ken set it at 32K in the first version (factory), then 128K in the second.
Cheers Don...
https://www.dontronics.com
DuinoMiteMegaAn
Posted: 12:40am 01 Dec 2011
@Don - ref. from Geoff site.
What do you make of these bugs?
I was able to confirm #1, #2 but not #3 yet.
#1 Version 2.7B was required to fix a bug in the virtual SD card storage?
#2 The RUN command will throw an error when you use a drive designator
(eg, "a:") to access a file on a drive that is not the default.
For example:
DRIVE "B:"
RUN "A:TST.BAS"
Will give an error.
While:
DRIVE "A:"
RUN "A:TST.BAS"
Will work as it should.
#3 Opening a flash file (drive A:) for APPEND will write incorrect
data to the file.
donmck
Posted: 12:46am 01 Dec 2011
  DuinoMiteMegaAn said   @Don - ref. from Geoff site.
For example:
DRIVE "B:"
RUN "A:TST.BAS"
Will give an error.
While:
DRIVE "A:"
RUN "A:TST.BAS"
data to the file.
Hi Andy, as there is no V2.7b source available yet, I know I have not concerned myself about anything to do with Drive A:-B: operation, as I felt it will work itself out. Ken may know something more.
Cheers Don...
ksdesigns
Posted: 12:58am 01 Dec 2011
if you would like to test the 2.7a-test version 256k flash drive
built in setup just type setup at > prompt
DuinoMite Setup Menu
V) Video Mode - PAL
R) RTC On Boot - OFF
D) Date Format - DD/MM/YY
S) SD Card - Enabled
U) Usb Console - Enabled
C) Serial Console - Disabled
B) Baud Rate - 115200
M) Custom Video Mode
P) Print Custom Video Mode
Q) Quit Dont Save Settings
X) Exit Save Settings
Video modes are for composite
PAL
Custom
Disabled
NTSC
NTSC-480 for wide screen lcd's
can disable sd card and just use internal storage
rtc and date format not yet implemented
MMbasic-Olimex-2.7A-test
ken
Edited by ksdesigns 2011-12-02
DuinoMiteMegaAn
Posted: 02:04am 01 Dec 2011
@KS ... So far ...
#1. Explain what RTC ON when boot?
#2. The SD status indication is flipped. <---<<<<
On reset it showed an error indicating there was NO SD.
Under setup it showed the SD card enabled?
Note: I had app which tries to access the SD on bootup using autorun.bas
#3. Someplace I read that you cannot have two consoles active
at the same time? You need to interlock the setup selections for U & C.
#4. What is com3 and com4? I have Uart2 on Uext, Uart5 on D0 & D1 and
Uart1 on D11&D12.
ksdesigns
Posted: 02:10am 01 Dec 2011
  DuinoMiteMegaAn said   @KS ... So far ...
Uart1 on D11&D12.
the rtc is for the olimex mod-rtc or a nxp real time clock
it will read the time at boot and set the maximite clock so you dont need a basic program to do that ..
ya i have a error on the sd card thing going to fix that tonight
and you can have video / usb /and serial consoles all at the same time ..
com3=uart2 com4=uart5 will add support for com1 and com2 the maxmite software uarts .
ken
djuqa
Posted: 02:42am 01 Dec 2011
Where oh where has My sound gone.
Where oh Where can it be
I turned on my Duinomite
But not a sound do I hear!.
Edited by djuqa 2011-12-02
VK4MU MicroController Units
DuinoMiteMegaAn
Posted: 04:20am 01 Dec 2011
@KS
Had to "fallback" to the factory 2.7 firmware.
I could not access the files on drive b: and
the autorun did not work.
Back to 32,608 bytes on drive a:
donmck
Posted: 04:27am 01 Dec 2011
What brand card Andy?
Cheers Don...
DuinoMiteMegaAn
Posted: 04:47am 01 Dec 2011
DuinoMite Mega Rev. C Factory Firmware 2.7
or do you mean my Sandisk 2 GB card, which always
work for me with the factory board? Edited by DuinoMiteMegaAn 2011-12-02
ksdesigns
Posted: 04:48am 01 Dec 2011
  djuqa said   Where oh where has My sound gone.
are you using the new version posted ?
then your sound must be broken because it works for every one else
are you using the rca or 3.5mm
and are you using a mono 3.5mm because that will sort out the sound
using microchip v2.01 compiler on it so now sd cards that didn't work before work now and some don't know so working that out now .
ken
donmck
Posted: 05:42am 01 Dec 2011
ken
We have tested using the file above, and both RCA and 3.5mm and it is working fine.
Mick tested 3.5, I tested RCA.
Here is the music file we tested it with:
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Basic%2FMusic%2F
I too found the SD got lost on the latest version with some SD cards, so hopefully the recompile will fix this.
BTW.
My Sandisk 8gig stopped working also, load in the previous version, and it is fine. Found the same thing with a new card I got today. A 4Gb "TEAM" from TW.
Cheers Don...Edited by donmck 2011-12-02
djuqa
Posted: 06:03am 01 Dec 2011
it says version 2.7 KSD
donmck
Posted: 06:15am 01 Dec 2011
  djuqa said   it says version 2.7 KSD
That is the factory one David, no sound.
New one has sound and the "setup" menu, however there appears to be a compile problem, and some SD cards don't like it. It doesn't have KSD on it.
Ken hoped to get it going tonight his time, I think was his words.
Cheers Don...
djuqa
Posted: 06:14am 01 Dec 2011
just installed version 2.7a
sound works
and the morse..bas program doesn't crash
SD cards work form
8gb verbatim /4gb sdHC (aldi) / 1gb sandisk
donmck
Posted: 06:23am 01 Dec 2011
sound works
SD cards work form
great, thanks for the feed back David.
Cheers Don...
VK6MRG
Posted: 06:48am 02 Dec 2011
Don, I love the music file that you posted!
donmck
Posted: 06:59am 02 Dec 2011
  VK6MRG said   Don, I love the music file that you posted!
Thanks I got it from Ken, I don't know if he did it or not.
Cheers Don...
Olimex
Posted: 01:24pm 02 Dec 2011
I think Ken was inspired by this performance Super Mario
