Local Time 03:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Upgrading to v2.7B
Ben Baker
Posted: 12:57am 22 Nov 2011
Hi fellers. My problem is upgrading to v2.7b. On Geoff's web page, he directs users to the download link at the bottom of the page which he says can be applied via USB (and Windows)and that all s/w and instructions are included in the download. The download produces two files - MM update v2.7b.hex and readme.txt. The latter states that the update is loaded using the BootLoad.exe program, but this doesn't appear to be in the download, nor do there appear to be any definitive instructions. I seem to be missing something which no doubt is patently obvious to those that have been down this track, so I seek help. Where do I go from here? Ben Baker.
CircuitGizmos
Posted: 01:02am 22 Nov 2011
Ben: Find the "regular" 2.7 upgrade. The bootload.exe program should be in there. You can use it to upgrade to 2.7B or even downgrade to an earlier version - just point to the desired .hex file.
Maximite_Update_V2.7A.zip Edited by CircuitGizmos 2011-11-23
