Local Time 19:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Software resources
erg322
Posted: 04:33am 20 Nov 2011
Et All,
I'm not sure...Mia Culpa if I missed it but if your after basic programs you have David Ahl's volumes to chew through and another great resource is the CPMUG discs or the the begining of the SIGM volumes whichever you find.
These are around the web and were published on a CD of CP/M material some years back. If you go to the Commercial CP/M website I recommend you wind your downloader back to one channel as the owner is touchy about bandwidth and has shut down whole domains for "pig in trough" downloading.
Dig into the CPMUG volumes and you will find things written in Bill Gates basic, Ebasic and DRbasic and the range goes all the way to even a chess program. Unless they have been uncompressed(your lucky) they will be compressed in ARK files. I found that on Windows 7 I could use IZARC and open the ARK file using *.* to input it.
Hope this helps.
