Local Time 03:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DuinoMiteMegaGPIO R1 Quick Reference
DuinoMiteMegaAn
Posted: 10:58am 17 Nov 2011
Created with OpenOffice rev. 3
Any amplifications, corrections, additions, deletions and comments welcome.
2011-11-17_205658_DuinoMiteMegaGPIO_R1.pdf
2011-11-17_205804_DuinoMiteMegaGPIO_R1.zip
donmck
Posted: 04:43pm 17 Nov 2011
  DuinoMiteMegaAn said   Created with OpenOffice rev. 3
Thanks very much Andy, I have added it to:
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Hardware%2FDontronics%2FOlimex%2F
Please let me know when you do updates.
Cheers Don... Edited by donmck 2011-11-19
https://www.dontronics.com
DuinoMiteMegaAn
Posted: 05:19pm 17 Nov 2011
Don
FYIO ... The zip file (205804) contains the OpenOffice (cal) spreadsheet that produced the PDF. A user can modify this spreadsheet if need be.
donmck
Posted: 07:31pm 17 Nov 2011
  DuinoMiteMegaAn said   Don
OH, OK
Thanks Andy. Have added it also.
Cheers Don...Edited by donmck 2011-11-19
DuinoMiteMegaAn
Posted: 11:37pm 17 Nov 2011
I would like to point out some of the details in the
DuinoMiteMegaGPIO R1 Quick Reference.
All information was obtained from many documents and links which makes this spreadsheet so easy to use by anyone who purchases or owns the DuinoMite Mega board rev. C.
Documents references:
1. Revision C Schematic DuinoMite Mega by Olimex.
2. The evolution of the DuinoMite and the differences between DuinoMite and
MaxiMite by Olimex.
3. UEXT.PDF by Olimex.
4. Link: http://www.thebackshed.com/forum/forum_topics.asp?FID=16&PN= 1
5. Link: http://www.themaximitecomputer.com/duinomite-gpios-explained -and-firmware-news/
6. Maximite MMBasic User Manual V2.7
What does this DuinoMiteMega GPIO R1 Quick Reference PDF spreadsheet show?
1. Shows the SetPin GPIO number in brackets "[#]" for I/O types for the DuinoMite Mega. Analog Inputs, Digital Inputs, Frequency Inputs, Period Inputs, Counter Inputs, Interrupt Inputs (L-H Rising)
(H-L Falling), Digital Outputs, Digital Outputs (+5VDC Open Collector).
2. What "Digital Inputs" that can have +5 VDC applied to them without component failure. (In red - +5 V Tolerant)
3. What "Digital Outputs" (+5 VDC Open Collector) that can have +5 VDC. (In red)
4. Shows all GPIO numbers that are NOT shared by other connectors, Arduino Shield(s) or devices. (x in row color white) (The count is 10)
5. Shows all shared GPIO numbers that are shared by other connectors, Arduino
Shield(s) or devices. (Yellow rows)
6. Describes the shared GPIO Functions eg SPI (CLK, MISO,MOSI,#SS), UARTs, I2C(SDA & SDL),SD SPI(CLK, MISO,MOSI)
7. Shows all UARTs on the DuinoMite Mega.
8. Shows both "on board" and external UEXT I/O that is shared with other devices, connectors and Arduino Shield(s).
Enjoy ...
donmck
Posted: 03:40am 18 Nov 2011
  DuinoMiteMegaAn said   I would like to point out some of the details in the
Andy, I have added this as a text file to:
I know that you or others will add to it, but if you let me know when there are updates, I'll replace the files as required.
Cheers Don...
DuinoMiteMegaAn
Posted: 11:13pm 09 Dec 2011
I updated the DuinoMite GPIO Quick Reference
To it, I added all the UARTS and comports and made some other minor text corrections.
Again,if you see any errors, in the document, please do state you deletions, corrections, additions and amplifications.
2011-12-10_091304_DuinoMiteMega_Input_Output_R3.zip
2011-12-10_091338_DuinoMiteMega_Input_Output_R3.pdf
donmck
Posted: 11:33pm 09 Dec 2011
  DuinoMiteMegaAn said   I updated the DuinoMite GPIO Quick Reference
Thanks very much Andy, have added to:
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Hardware%2FDontronics%2FOlimex%2FDocuments%2F
Cheers Don...
DuinoMiteMegaAn
Posted: 10:32am 10 Dec 2011
I hope Olimex would chime in on this GPIO document on any obvious errors. Edited by DuinoMiteMegaAn 2011-12-11
donmck
Posted: 10:38am 10 Dec 2011
  DuinoMiteMegaAn said   I hope Olimex would chime in on this GPIO document on any obvious errors.
Thanks Andy, I'll send them a note.
Cheers Don...
