Local Time 02:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : hung hardware/software
hammo
Posted: 10:56am 15 Nov 2011
hey maximite experts
when i force halt my program during debug,
normal operation cannot be resumed until i cycle the power and reload
what is the preferred method to restore the maximite to a known state when debugging?
i think problem may be associated with an incomplete interrupt
this newbie would appreciate any assistance
hammo
hammo
sparkey
Posted: 11:12am 15 Nov 2011
more info please
: maxi make and model and r u running through a term program
:we are up to version 2 point 7 b or a in firm ....
hammo
Posted: 01:39am 16 Nov 2011
maximite was procured from dontronics in august
it is marked sm1
i have done my edits using teraterm via usb on a windows computer
it seems to work nominally
i have not tried to update from the supplied 2.5 firmware
when my code is under test and it hangs the only way i can find to exit is ctrl/c
i have found that restarts after that go differently if i have recycled the power and reloaded
i thought that perhaps there was a better way to reset the card than ctrl/c because if i stop it during an interrupt routine it may get confused
i dont feel that i have hardware issues - just that i may be short on technique
hammo
CircuitGizmos
Posted: 01:56am 16 Nov 2011
I would recommend upgrading to the newest firmware.
A hardware reset to the SM1 can be done with CON3. Connect pins 1 and 3 with a momentary pushbutton. This will reset the PIC32.
hammo
Posted: 05:05am 16 Nov 2011
the hardware reset functions as advertised but requires a software reload afterwards
the newer 2.7 firmware happily fixed my problem where it failed to restart (without a software reload) following a ctrl/c forced halt
thank you for your prompt interest
onwards and upwards ...
hammo
