Local Time 19:03 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card wiring on the UBW32.
aargee
Posted: 11:52am 29 Oct 2011
Geoff,
My first UBW32, which had the original wiring and conversion for the original Maximite, worked fine with the SD card, etc.
I modified my wiring on this UBW32 for the SD card to match the diagram in the 2.7 manual, but all I get is "Error: Cannot access the SD card" is the wiring diagram correct? Without the SD card in place I get "Error: SD Card not found".
I have triple checked the wiring as per P5 of the users guide.
- Rob.
