Local Time 02:47 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug fix for MMBasic V2.7
Posted: 08:42am 28 Oct 2011
Unfortunately Anthony (in this thread ) found a bug in the handling of the internal flash drive A: in 2.7. It shows up as four lost bytes for every 4076 bytes written to a file.
This was sufficiently important to put out an immediate fix (ver 2.7A) which you can download from http://geoffg.net/maximite.html. The updated source code can be found at the same location.
This release also fixes a couple of other bugs and adds one feature (details in the change log). A matching release for the UBW32 is available from http://geoffg.net/ubw32.html.
Don't forget to backup your drive A: before installing the update as it will clear that drive.
Apologies for the messing around,
Edited by Geoffg 2011-10-29
Posted: 09:17am 28 Oct 2011
Damn, there was a bug in that version related to composite video. If you have downloaded it please do it again - the version now there fixes it.
sparkey
Posted: 09:54am 28 Oct 2011
geoff did you slow the timer count down on the XMODEM it seems slower now and it is ezier to load up the hy-tem protcol and stuff or is it me thats being decived by my computer ...sparkey...oh i was running on com 6 baud 9600 proto XMODEM and the file was sent to the maxi ..i am also using an "ev" board from don and so hyper-term working ...sparkey...///
Posted: 10:23am 28 Oct 2011
No sparkey, I did not change anything in that area. I was in too much of a panic to get this fix out. I will look at it later.
sparkey
Posted: 11:44am 28 Oct 2011
well it is slower atm i am running at 38000 baud it copied the file battery.bas ..but i cannot load the file ;it comes up with an error "line to long" i spose this is documented in the manual but cant seem to find it ...or was it because i was using a too fast baud speed ...dunno...thanks sparkey
sparkey
Posted: 03:59pm 28 Oct 2011
i have the maximite "ev" from don connected via hy-term and did a file transfer from pc to drive A with a jpg file ... the quickest time i can transfer this file is 16 seconds its a 91k file "battery.jpg" mm manual says that the highest speed is "19200" ...though i have it set a higer baud does it only see 19200 baud ...????...///...//Edited by sparkey 2011-10-30
ajkw
Posted: 02:45am 29 Oct 2011
Geoff,
Sorry for the panic! The 4K bug certainly got my attention/curiosity when testing the copy program and seeing the small change in file size.
Cheers,
Anthony
crackerjack
Posted: 12:17pm 30 Oct 2011
A very minor update to the Quick Reference is available - essentially this just includes the features added in 2.7A which are OPTION USB and OPTION VIDEO.
arvindk
Posted: 10:37am 31 Oct 2011
Hi everyone
I have just joined the forum and apologise if I am in the wrong place for my question.
I have just upgraded to Version 2.7A, but have not been able to figure out how drive A: is accessed. Anything I do seems to point to the SD card, but I cannot work out how one switches from drive B: to A: or vice versa, or what is the indication what drive you are using. Can"option prompt " be set to indicate the drive letter as in old-fashioned DOS ?
I am relying here on the old saying that the only stupid question is the one that was not asked, LOL
ak
sparkey
Posted: 10:47am 31 Oct 2011
:syntax: drive":a"
this will swap drives for you ...welcome regards sparkey ...///...///or
drive ":a"
with or without a space not shure tired...
sparkey
Posted: 10:51am 31 Oct 2011
dsyntax: <? mm.drive> will show you the drive that you are logged to...
crackerjack
Posted: 12:10pm 31 Oct 2011
@arvindk, try the following for something like the good "Old Fashioned DOS" prompt:
[code]OPTION PROMPT MM.DRIVE$+CWD$+">"[/code]
Which will give you the something like:
[code]A:\MYDIR>[/code]
...or even more useful, you can include the current file name you are editing (since SAVE, RUN, etc work against this from v2.6 onwards):
[code]OPTION PROMPT MM.DRIVE$+CWD$+"\"+MM.FNAME$+">"[/code]
Which will give you something like:
[code]B:\GROOVY\STUFF.BAS>[/code]
You could go nuts and inlcude TIME$, DATE$, or whatever, but it starts to eat into the available line space...
You can include the above in your AUTORUN.BAS.
Cheers...
arvindk
Posted: 09:21pm 31 Oct 2011
Thanks to all for your help. I do feel sorry that I did not follow the age-old advice of RTFM !!
Although mm.drive$ is listed in the manual, I would not have known that 'drive' was a valid command and needs to be followed by a string (with the drive letter). I do not remember this from my GW-Basic days.
I find the Maximite a great little tool and the forum matches it. Great job Geoff and all of you senior members.
I also have a UBW32 from Sparkfun and will load Maximite version of MMBASIC into it today. I rather like its 50-pin capability.
Back to work now
ak
