Local Time 02:36 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Programming in assembly language
Worm
Posted: 01:12am 15 Oct 2011
Does anybody know of a good forum on progamming in assembly language? Trying to search for code snippets on the 12f617 is proving difficult. Any advice would be appeciated.
Kevin
There's no such thing as a free lunch.
ksdesigns
Posted: 02:00am 15 Oct 2011
What do you need ??
ken
Worm
Posted: 02:25am 15 Oct 2011
Hi Ken
Ive written a program using a 10f206 and now want to transfer the program to a 12f617. The problem for me is I find it very difficult to understand the data sheets. I need to configure the 12f617 for 2 inputs and 3 outputs, and also how to turn on a O/P. If I had some code to blink a LED, I then could work out how to modify it untill I can get it to work with my own program.
Kevin
ksdesigns
Posted: 04:45am 15 Oct 2011
http://www.voti.nl/swp/ is a good start
any reason for the 12f671 ? 12f683 is a better part plus 256 bytes eeprom and probably cheaper .
and if you need more speed 12f1822 is a great part.
they are all the same 35 instructions to learn.
The company i work for probably buys a few million of 683 and 1822's a year so i do a lot of stuff with them
ken
Worm
Posted: 05:18am 15 Oct 2011
Hi Ken
The reason for using a 12f617 is I have 10 of them. Ive had a quick look at that web site you sugested. They have code to flash a LED but it is not in asm or for 12f617,s. The problem I am having is learning how to configure the more complex micros. Thats why I asked for code specific for a 12f617.
Kevin
Olimex
Posted: 06:29am 15 Oct 2011
www.piclist.com have nice archive
Bryan1
Posted: 07:59am 15 Oct 2011
Hi Kevin,
For getting your feet wet in assembly language you can't go past Nigel Goodwin's pic Tutorials.
Regards Bryan
vasi
Posted: 11:44pm 17 Oct 2011
You can use JALv2 language to blink a LED then, you can study the .asm file. You have support for that on Jallib libraries. It's all free.
[code]include 12f617 -- target PICmicro
-- This program assumes that a 20 MHz resonator or crystal
-- is connected to pins OSC1 and OSC2.
-- (unspecified configuration bits may cause a different frequency!)
pragma target clock 20_000_000 -- oscillator frequency
-- configuration memory settings (fuses)
pragma target OSC HS -- HS crystal or resonator
pragma target WDT disabled -- no watchdog
pragma target MCLR external -- reset externally
-- These configuration bit settings are only a selection, sufficient for
-- this program, but other programs may need more or different settings.
enable_digital_io() -- make all pins digital I/O
-- Specify the pin to which the LED (with serial resistor!) is connected:
alias led is pin_A0
pin_A0_direction = output
forever loop
led = on
_usec_delay(250_000)
led = off
end loop
[/code]
And the resulted assembler:
[code]; compiler: jal 2.4o (compiled May 8 2011)
; command line: ../compiler/jalv2 -s ../lib 12f617_blink.jal
list p=12f617, r=dec
errorlevel -306 ; no page boundary warnings
errorlevel -302 ; no bank 0 warnings
errorlevel -202 ; no 'argument out of range' warnings
__config 0x3ff2
datahi_set macro val
bsf 3, 6 ; STATUS<rp1>
endm
datahi_clr macro val
bcf 3, 6 ; STATUS<rp1>
endm
datalo_set macro val
bsf 3, 5 ; STATUS<rp0>
endm
datalo_clr macro val
bcf 3, 5 ; STATUS<rp0>
endm
irp_clr macro
bcf 3, 7 ; STATUS<irp>
endm
irp_set macro
bsf 3, 7 ; STATUS<irp>
endm
branchhi_set macro lbl
nop
endm
branchhi_clr macro lbl
nop
endm
branchlo_set macro lbl
bsf 10, 3 ; PCLATH<3>
endm
branchlo_clr macro lbl
bcf 10, 3 ; PCLATH<3>
endm
v_on EQU 1
v_off EQU 0
v_output EQU 0
v__gpio EQU 0x0005 ; _gpio
v__porta_shadow EQU 0x0023 ; _porta_shadow
v_cmcon0 EQU 0x001a ; cmcon0
v_cmcon1 EQU 0x001c ; cmcon1
v_adcon0 EQU 0x001f ; adcon0
v_trisio EQU 0x0085 ; trisio
v_pin_a0_direction EQU 0x0085 ; pin_a0_direction-->trisio:0
v_ansel EQU 0x009f ; ansel
v__pic_temp EQU 0x0020 ; _pic_temp-->_pic_state
v__pic_state EQU 0x0020 ; _pic_state
v___x_22 EQU 0x0023 ; x-->_porta_shadow:0
v___x_23 EQU 0x0023 ; x-->_porta_shadow:0
; 25 include 12f617 -- target PICmicro
org 0
l__main
; 38 enable_digital_io() -- make all pins digital I/O
; ../lib/12f617.jal
; 462 ANSEL = 0b0000_0000 -- all digital
datalo_set v_ansel
clrf v_ansel
; 12f617_blink.jal
; ../lib/12f617.jal
; 484 analog_off()
; 12f617_blink.jal
; ../lib/12f617.jal
; 469 ADCON0 = 0b0000_0000 -- disable ADC
datalo_clr v_adcon0
clrf v_adcon0
; 12f617_blink.jal
; ../lib/12f617.jal
; 485 adc_off()
; 12f617_blink.jal
; ../lib/12f617.jal
; 476 CMCON0 = 0b0000_0000 -- disable comparator
clrf v_cmcon0
; 477 CMCON1 = 0b0000_0000
clrf v_cmcon1
; 12f617_blink.jal
; ../lib/12f617.jal
; 486 comparator_off()
; 12f617_blink.jal
; 42 pin_A0_direction = output
datalo_set v_trisio ; pin_a0_direction
bcf v_trisio, 0 ; pin_a0_direction
; 44 forever loop
l__l46
; 45 led = on
datalo_clr v__porta_shadow ; x22
bsf v__porta_shadow, 0 ; x22
; ../lib/12f617.jal
; 202 _PORTA = _PORTA_shadow
movf v__porta_shadow,w
movwf v__gpio
; 12f617_blink.jal
; 45 led = on
; 46 _usec_delay(250_000)
datalo_clr v__pic_temp
datahi_clr v__pic_temp
movlw 167
movwf v__pic_temp
l__l56
movlw 9
movwf v__pic_temp+1
l__l57
movlw 165
movwf v__pic_temp+2
l__l58
branchhi_clr l__l58
branchlo_clr l__l58
decfsz v__pic_temp+2,f
goto l__l58
branchhi_clr l__l57
branchlo_clr l__l57
decfsz v__pic_temp+1,f
goto l__l57
branchhi_clr l__l56
branchlo_clr l__l56
decfsz v__pic_temp,f
goto l__l56
nop
nop
; 47 led = off
bcf v__porta_shadow, 0 ; x23
; ../lib/12f617.jal
movwf v__gpio
; 12f617_blink.jal
; 47 led = off
; 48 _usec_delay(250_000)
movlw 167
movwf v__pic_temp
l__l59
movlw 9
movwf v__pic_temp+1
l__l60
movlw 165
movwf v__pic_temp+2
l__l61
branchhi_clr l__l61
branchlo_clr l__l61
goto l__l61
branchhi_clr l__l60
branchlo_clr l__l60
goto l__l60
branchhi_clr l__l59
branchlo_clr l__l59
goto l__l59
nop
nop
; 49 end loop
goto l__l46
end
[/code]
I don't know if it helps for your assembler but... you can get nice results in JALv2...
The project page is here,
Elvish name: Mablung Miriel
Beyound Arduino Lang
