Local Time 02:36 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite Tester
johnbig
Posted: 03:23am 14 Oct 2011
Has anyone thought about a testing module for the Maximite?
I was thinking about some hardware and a software solution to exercise all the i/o pins and 5 volt and 3.3 voltages. I think I have damaged pin 1 on my maximite because I got confused with the 26 pin i/o connector assignments between a cross over cable and straight cable and also hooked a 1.2 volt rechrgeable the wrong way around on pin 1 in the geoffg battery capacity tester.
John Leae
sparkey
Posted: 12:20am 17 Oct 2011
i have put foward the basically same idea a while back ...this is a suggestion go to the maximite whish list its by "donmick" and leave a post there i think that somebody will do it eventully even if its just a straight led test board ..i would do it my self but ..i cannot code very well the hard whare would not be too difficult but some body woud have t write the code and ..i think things like loop back connectivity on the com ports ...etc..etc... i think there is good reason for this unit ....regards sparkey
and on a nother thought it may be possible just to run a diag program as long as the pins are tru to the software ....and not miss reported...
and on another point the analog pins are rated at 3.3 volts i/o....Edited by sparkey 2011-10-18
