Forum Index : Microcontroller and PC projects : Maximite’s First Words via Email
rhamer
Posted: 03:09am 09 Oct 2011
Folks,
I have just got my Maximite to send emails, without a PC.
It is done via the functionality provided on my Ethernet board thanks to the XPort module.
The emails can be triggered in 2 ways;
By toggling one (or more) of the 3 GPIO pins on the XPort that are connected through to the Maximite. eg PIN(14) = high will trigger a pre-configured email.
or
By setting a 1 or 2 code serial sequence that the maximite can send via its serial port.
The emails are preconfigured and very simple (in fact they contain no message body, just a subject that you can set)
However if you had a few alarm conditions that you wanted to know about, it would do the job.
I have got it talking through my ISP's (BigPond) mail server.
Rohan
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
elproducts
Posted: 03:18am 09 Oct 2011
Having that email sending code snippet for download it exactly what I refer to in my most recent post to your board announcement topic.
That sounds very interesting and makes me consider your boards even more for some future projects I'm planning.
www.elproducts.com
sparkey
Posted: 11:43am 09 Oct 2011
would it also be possible to have a bit map like you see when you type up a "e-mail" i will draw a picture but i dont have my scanner loaded up to the machine atm will post later ...or am i missing ..also i found a serial modem 33k which would that also be possible to connect up to the maxi via the rs-232.port ...maybe i`m just way off base but thats my thoughts ...regards sparkey...///...///
