Local Time 02:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Bug (I Think)
jman
Posted: 05:50am 17 Sep 2011
Hi
It seems there maybe an issue with the serial code
Can somebody please else confirm this
10 SETPIN 17, 8 : SETPIN 18, 8 : SETPIN 19, 8 : SETPIN 20, 8
20 OPEN "COM1:9600" AS #1
30 PRINT #1, "Any Text"
This will not output anything on the serial port
10 SETPIN 17, 8 : SETPIN 19, 8 : SETPIN 20, 8 ' SETPIN 18 removed and it now works
If i include a SETPIN for pin 18 it kills the serial port ?
BobDevries
Posted: 06:09am 17 Sep 2011
John,
according to the manual (page 22) COM1 uses pin 15 for receive, 16 for transmit, 17 for RTS, and 18 for CTS.
COM2 uses pin 19 for receive and 20 for transmit.
When a serial port is opened the pins used by the port are automatically set to
input or output as required and the SETPIN and PIN commands are disabled for the
pins. When the port is closed (using the CLOSE command) all pins used by the
serial port will be set to a not configured state and the SETPIN command can
then be used to reconfigure them.
Hope that helps
Bob Devries
Dalby, QLD, Australia
jman
Posted: 06:18am 17 Sep 2011
Thanks Bob
It is not pin18 that stops it is the serial that stops
I am not using rts or cts so pins 18 and 19 should be free for use
Bill.b
Posted: 07:00am 17 Sep 2011
Hi John
I do not know if this applies to maximite but when I used serial comms via a uart and if you did not require CTS and RTS, you had to bridge CTS and RTS for comms to work.
seco61
Posted: 07:01am 17 Sep 2011
Hi John.
I have just checked the source code and their is a bug in the code.
In the SerialOpen routine, the following line:
com1_fc = true;
Should be
com1_fc = fc;
So, COM1 is always being opened with flow control enabled. However the code is correctly setting the pin status as it is using "fc" for that check - which means that when you set the pin as a digital output the code is waiting for a valid CTS signal - which it can not get.
If you are able to compile the code then you can make the above change and that should fix your issue.
Gerard (vk3cg/vk3grs)
jman
Posted: 07:23am 17 Sep 2011
Thanks Gerard
I have not tried to complie the code yet
Any chance I could be a real pain and ask you to post the fixed
Complied code here
Many thanks
Posted: 02:10am 18 Sep 2011
Hi John,
I found this bug a few days ago. I did list it on my website http://geoffg.net/Downloads/Maximite/Firmware_V2.6_Bug_List. txt but I must admit that you need to know where to look!
I did not figure that it was a major issue as there are plenty of other I/O pins available so I was going to leave the fix until ver 2.7 (due out in about 5 weeks).
Is it a big issue for you?
sparkey
Posted: 02:28am 18 Sep 2011
you should have written it as this
10 'initalise i/o pins
20 setpin (pin)
30 setpin (pin)
and so forth you are using one line to set all pins
hope this helps sparkey....regards "i may be wrong but i may be write""...Edited by sparkey 2011-09-19
jman
Posted: 04:59am 18 Sep 2011
  Geoffg said   Hi John,
Nope not really just got confused as to why the serial comms was not going
