Forum Index : Microcontroller and PC projects : Plastic Enclosure
rofa
Posted: 07:34pm 10 Sep 2011
Can anybody tell me, what type of the plastic enclosure is used for the MM ?
I mean the white/grey box.
Thanks in advance,
Jiri
donmck
Posted: 07:40pm 10 Sep 2011
  rofa said   Can anybody tell me, what type of the plastic enclosure is used for the MM ?
Thanks in advance,
Jiri
I was a little confused on this until Sparkey set me straight two days ago.
For the original board, it is an Altronics HO376 case. Snap together 130 x 75 x 28mm.
But it appears that it may not be listed in the latest catalogue, so I don't know if it can be purchased separately, or still available.
Cheers Don...Edited by donmck 2011-09-12
https://www.dontronics.com
ajkw
Posted: 10:40pm 10 Sep 2011
Altronics cat 2011-12 page 233 bottom left corner. Also on the website. Is part number H0376 not HO376, that is zero not O.
donmck
Posted: 10:45pm 10 Sep 2011
  ajkw said   Altronics cat 2011-12 page 233 bottom left corner. Also on the website. Is part number H0376 not HO376, that is zero not O.
that b him
Cheers Don...
rofa
Posted: 05:31pm 11 Sep 2011
Thank you very much.
Jiri
sparkey
Posted: 05:55pm 11 Sep 2011
yes it is still a current stocked item
