Local Time 01:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beginners blinking led code
FrankMc
Posted: 06:20am 28 Aug 2011
Hi Guys
Apologie,s for the newbie questions..But do we have any sample code for say blinking an led...
Frank
Edited by FrankMc 2011-08-29
Posted: 06:46am 28 Aug 2011
  FrankMc said   Hi Guys
Frank
Hi Frank,
This code will flash the Power LED is actually on Pin(0)
10 pause 500:pin(0)=0:pause 500:pin(0)=1:pause 500:pin(0)=0:pause 500:pin(0)=1:pause 500:pin(0)=0:pause 500:pin(0)=1
If you want to blink an LED on another I/O pin you will need to set it first as a Digital Output Setpin x,8 (see page 13 of the manual) where x is the pin you wish to use.
MickEdited by bigmik 2011-08-29
FrankMc
Posted: 07:27am 28 Aug 2011
Frank
Hi Frank,
Hi Mick
I copied and pasted the sample you gave but when i hit enter no flashy led...Do you have to type each command in with line number...??
Frank
ajkw
Posted: 07:46am 28 Aug 2011
Frank,
Did you run the program after pasting in Mick's code??
Another example would be
5 ppin = 1
10 for i = 1 to 20
20 ppin = not (ppin) 'ppin value will alternate a value of 0 or 1
30 pin(0) = ppin 'set the led on or off per value of ppin
40 pause 200 'pause for a time in milliseconds.
50 next i
60 pin(0) = 1 'leave the led on once we are finished
Anthony.
donmck
Posted: 07:51am 28 Aug 2011
If you have an SD Card Frank, just copy the file as "flash0.bas" to it.
Then load "flash0.bas" to the maximite.
"list" to make sure it is there.
Then "run"
https://www.dontronics.com
Posted: 07:56am 28 Aug 2011
10 setpin 0,8
20 pin(0)=1
30 pause 200
40 pin(0)=0
50 pause 200
60 goto 20
Posted: 09:42am 28 Aug 2011
Frank
Hi Frank,
Hi Mick
Frank
The line number (10) is there..
When you cut and pasted it should have loaded the program into the Maximite
To start the program
type RUN
FrankMc
Posted: 10:11am 28 Aug 2011
  bigmik said
Frank
Hi Frank,
Hi Mick
Frank
type RUN
Thanks Mick
That did the trick....Looks like i have lots of reading to do...
Frank
FrankMc
Posted: 10:28am 28 Aug 2011
Thanks for the replys guys
im going to build Rohans boards and then try and get some i/o working...I have the Maximite manual prined out so i,ll read some but im sure i,ll have more dumb questions soon..
Frank
Posted: 08:43pm 28 Aug 2011
  FrankMc said
Thanks Mick
Frank
No worries,
We all start somewhere...
Now the fun begins..
regards,
donmck
Posted: 08:49pm 28 Aug 2011
Reminds me of when I wrote my first "HELLO WORLD" program in March 1978 on my TRS-80 Model-I.
Don't do what I did. Spend 8 hours writing a program, then have your wife switch your computer off, so she can plug in a double adapter to do the ironing, and you haven't done a back up.
Cheers Don...
Posted: 08:52pm 28 Aug 2011
Cheers Don...
I bet it was the BEST program ever written in the history of the world too?
aargee
Posted: 09:46am 29 Aug 2011
Gees, Don, it took you eight hours to write a "Hello World" program?
- Rob
donmck
Posted: 03:25pm 29 Aug 2011
  aargee said   Gees, Don, it took you eight hours to write a "Hello World" program?
- Rob
Yes, and flashing LEDs took 16 hours, so these newbies "ain't seen nothing yet".
I didn't realize that some newbies had no programming experience whatsoever, so the flashing LED type programs, are a very good step in the right direction.
If we are to introduce Maximites to kids and schools, we need some basic tutorials, to get them started.
I am prepared to host something on my blog, but writing them is another thing, as I am always pushed for time.
If no one else wants to do something, I may attempt something simplistic to at least get it started.
Cheers Don...
Dinosaur
Posted: 11:14pm 29 Aug 2011
Hi all
I would start by pointing them to here
http://www.o-bizz.de/qbtuts/gw-train/index.htm
Then it only needs a small article about the oddities of the MmBasic.
Hervey Bay Qld.
Worm
Posted: 11:26pm 29 Aug 2011
Don, Im sure that would be an appreciated by a lot of newbies including myself. Progaming can be very difficult and frustating to learn without help and also very rewarding when something works. Tutorials with some code would be very helpfull including some simple things that we take for granted like always start with the "NEW" command so we dont end up with a mixed up program from previous tries that may stop it from working.
Kevin
There's no such thing as a free lunch.
