Local Time 01:47 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Speeding up The Maximite
Posted: 11:22pm 18 Aug 2011
I have been thinking,
I know, this usually means trouble But...
As the MM has to display out the VGA port, how much speed up of code iteration would we achieve if we were able to tell MM basic to cease Console I/O and just run the code?
Ie. a command CONSOLE OFF (ON) would toggle keyboard, VGA and USB I/O so that the fastest possible iterations of normal code can be performed by not servicing these functions.
Would this generate some speed improvment or is it really minimal?
Mik
vasi
Posted: 11:32pm 18 Aug 2011
And that qualifies for a wish...
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 11:51pm 18 Aug 2011
I think the VGA is processed indepently from the core. I remember reading somewhere Geoff used one of the serial UART's as a VGA output device, and it just runs in a loop reading from memory, freeing up the core to do other stuff. I could be totaly wrong though
Its only when new data is written to the video memory that the core is involved. So in theory if nothing is changed on the screen output, there would be no gain in turning it off.
Keyboard could be another matter, its waiting for user input all the time, even if just a CRTL-C. But again, I dont know how involved the core is with this.
Dinosaur
Posted: 06:44am 19 Aug 2011
Hi all
Mik a coincidence that I have finally received my mm, and did a speed test.
A very simple program like:
10 Option Bas1 1
20 StartTime = Timer
30 For X = 1 To 1000000
40 Next x
50 Print Timer-StartTime
60 End
takes 83736 mSec. That equates to 23.884 lines per mSec
And thus 23884 lines per Sec. Where is the 30,0000 lines per sec.
Am I wrong, by saying this is only executing one line, is a For Next 2 Lines ?
Changing the code to
10 Option Base 1
30 For X = 1 To 1000000:Next X
60 End
takes about the same time
Hervey Bay Qld.
Posted: 06:56am 19 Aug 2011
I dont think lines per second is a good way to measure a computers speed. It would depend on what commands are issued on that line. eg a gosub or pause. Also incrementing variables can have a dramatic slow down when they reach a certain size. I know when programming in VB I have to watch string lengths, eg C="A"+"B" wont take long, but if we have a string thats a few thousand characters long instead of just "A", then its a big CPU hit, even though it appears to be a simple command.
Also, what are we comparing the Maximite to? If I compare it to my old Microbee, then the Maximite is lightning fast. But compared to my current PC, its slow.
haiqu
Posted: 07:28am 19 Aug 2011
Dinosaur,
That's the same code, line numbers would be optimized away anyhow.
Good question about the video Mik, this might be important for critical embedded applications. Then again, would you use BASIC in that case?
Rob
Posted: 07:33am 19 Aug 2011
Hi Glenn,
I wasnt trying to compare speed...
I have actually bought some displays .. see link ... and am considering my interfacing options. And it looks like I will have to serially clock into a CD4040 or similar or use a few I2C latches to latch 16 bits across (2 chips) for each 8 dot character.. and then cycle through the 8 rows to display the dots a row at a time (fast cycle so it looks smooth) so I was wondering how fast basic would go at it and then came apon my idea and thought it might speed things up
FYI Displays I bought
regards,
Mick Edited by bigmik 2011-08-20
Posted: 07:39am 19 Aug 2011
  haiqu said   Dinosaur,
Rob
Hi Rob,
Seriously I WOULD use basic because that is ALL I know... I have tried to get my head around C but that is gibberish to me.
I really think a basic package that calls an optimsed C routine would probably be required in my application but I think that the VGA is effectively "Bit Banged" out it *HAS* to take some time and then scan for K/B.... but then I dont know enough about the Geoff's Magic code.
Mik
seco61
Posted: 09:33am 19 Aug 2011
  bigmik said   I have been thinking,
Mik
Hi.
Thinking is good and it is a thought that had occurred to me some time ago. I have become very familiar with Geoff's code and can offer some insight into the overhead.
First, to implement such a command would be very simple - though the implementation of the command would itself provide a very slight overhead in the case where it is in the CONSOLE ON state (but just 3 C "if" statements, which will equate to approximately 5 assembler instructions each...).
While the video subsystem utilises a combination of a SPI peripheral, a DMA channel (well 2 actually), an output compare module and a timer with its associated interrupt - it "should" be a very minimal overhead as most of the processing is done outboard from the CPU (with the exception of the timer interrupt). However, due to a "technical glitch", a dummy loop has been inserted in the routine and this takes at least 11% of the available CPU.
So disabling the video output routine (in its current state) would definitely provide a noticable benefit. I am currently playing with the video ouput code to see if I can find a way to avoid having to use the work around - but I do not know if I will succeed.
The keyboard scan routine currently executes every 20uS. Most of the time it has a very fast path through it (unless a key is pressed) and probably only adds 1 - 2%.
The USB check routine is currently called within the video interrupt. The recommendation is that this routine be executed every 100uS or so to ensure no buffer over-runs occur. I have not examined this code in detail (supplied by Microchip) so am not certain of its overhead. In my current code I have moved it to a different timer interrupt and call it less often. Also, as it is now in a lower priority interrupt it no longer interferes with the video display when I send a large amount of data from the terminal emulator (ie pasting in a large block of code).
Gerard (vk3cg/vk3grs)
vasi
Posted: 12:16pm 19 Aug 2011
Hi Gerard,
From the discussions from jallib group, if you have a lot of PWM outputs, a Serial comm is recommended instead of USB. But that was about PIC18F's. don't know how much count on a PIC32.
Vasi
seco61
Posted: 12:35pm 19 Aug 2011
Another thing that can be done to speed up the Maximite is to increase the "small data size" setting in the compiler options. However, due to what I consider to be a bug in the compiler, while the compiler correctly generates the code to support the size you supply, it does not place some of the variables into the correct section. And when the linker runs the variables are not grouped in the correct place and relocation fails.
The variables that are not placed correctly are global variables that do not have a "extern" declaration. These end up in the COMMON section instead of the .scommon section.
This can be fixed by changing the source to have a static attribute on the variables that do not require to be external. I have done this for testing purposes and it does make a significant difference to run time speed.
boss
Posted: 04:25pm 19 Aug 2011
Good morning from Canada,
I would like to contribute into discussion with couple of ideas:
first I have apologize for my bumpy English
now:
I'm pretty sure that maintain the VGA using the cpu is bare wasting of scarce CPU resources, the cheapest FPGA can is designed to perform such job in the superior quality and of course in color and as with many graphic support as we will be able design a program.
Well, here is group of experienced fine gentleman, let form a special group and talk about an advanced MAXIMITE. Geoff did the incredible job, let help him ( if he will be interested of course) to design next generation of MAXIMITE.
btw. It is an ideal solution for real time control and more.
Bo
pito
Posted: 05:01pm 19 Aug 2011
Bo, there has been a discusion on coloured vga - I passed this info to the maximites at that time:
http://excamera.com/sphinx/gameduino/
Ready to connect (via SPI) to maximite (or 1-2w of work on a new pcb).
Also there are some benchmarks I did - the fastest language you may run on maximite today is pic32Lua (an interpreter of bytecode, very fast on chip compilation (~mseconds), and runs programs from sdcard as well, and, it is very small- ~65kBytes maybe - interpreter and compiler all-in-one):
http://askrprojects.net/software/pic32lua/index.html
Currently only asm and C is faster. BTW, Lua uses 64bit float as default, and even so the Lua is 20-30times faster then maximite's basic.
PitoEdited by pito 2011-08-21
haiqu
Posted: 05:26pm 19 Aug 2011
Pito,
That may not be the case for very long, I just ported pForth. :-)
Rob
pito
Posted: 07:18pm 19 Aug 2011
Interesting, we tried to scale down pforth but still @ 256kB ram..
Any reference to your port?
Pito
