Local Time 01:28 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Modded Maximite-EV
ksdesigns
Posted: 06:35am 30 Jul 2011
Recompiled Maximite 2.5 removed all video and keyboard code (didn't need it)
Changed code from SD card to Usb flash drives
By removing SD card and Video opens 2 serial ports plus lots of other i/o pins
Changed Bootloader to load new firmware off usb drive :)
ken
sparkey
Posted: 06:50am 30 Jul 2011
ok so more deatails on what you have connected to the s-d slot and... i notice some wiring round the usb skct ..i have one of these boards right in front of me... but it`s alreaddy got a purpose... but if you can run the bootlader directly from the usb stick into the "maxi" thats pure genius..i do have three maxis on hand ...one the same as the photo ...well looks the same /one altronics/
one sm1 "tctec "Edited by sparkey 2011-07-31
donmck
I feel like all good hackable items, the Maximite may well lead an avalanche of modifications.
People have access to the hardware and source code.
Nice work Ken,
Cheers Don...
https://www.dontronics.com
ksdesigns
Posted: 06:57am 30 Jul 2011
the wires to the SDslot is serial port 2
sparkey
ditto
Keith @
Posted: 06:58am 30 Jul 2011
Well done Ken
That is awesome work which opens up another evolution of the Maximite. Creativity in action!
I'm sure that we will probably have another design of main board which will give us more of the pin outs sometime in the near future and maybe even use the 100pin version of the PIC32. Any takers?
Ken, are you going to put the hex code up on site?
Keith
The more we know, the more we know we don't know !
ksdesigns
Posted: 07:01am 30 Jul 2011
Ya should have the hex and source for the bootloader and the Maximite up by the weekend
also added a option date command
option date 1
fixes the date for us yanks month/day/year
ken
sparkey
Posted: 07:05am 30 Jul 2011
ok so you turn the unit on as well as having the bootloader switch depressed then ..i guess that it automaicicly lodes the hexfile that is on the usb stick and executes this all in that matter or am i in correct here
haiqu
Posted: 07:09am 30 Jul 2011
Nice hack!
Rob
ksdesigns
yep just call it image.hex and hold the button down while powering on and when the light goes off its done and will reboot into basic
and right now the console is on uart2 where the sd card was
ken
donmck
Posted: 07:13am 30 Jul 2011
  ksdesigns said   the wires to the SDslot is serial port 2
To pins 31 and 32 micro Ken?
No SD card = one Uart.
Cheers Don...
aargee
I agree, very nice. The Maximite platform lends itself very well to being a hacker space!
sparkey
Posted: 07:15am 30 Jul 2011
you must have to power it down to let it reboot...cheers ...
ksdesigns
Posted: 07:18am 30 Jul 2011
Yes don 31 and 32 are uart2
and if you disable video and remove R3 and U3 on that board you get Uart3 on pins 5 and 6 that are on holes in the board for headers U11 and U5
sparkey the bootloader reboots it so you don't have to cycle the power
ken
Edited by ksdesigns 2011-07-31
donmck
Posted: 07:24am 30 Jul 2011
  ksdesigns said   Yes don 31 and 32 are uart2
I take it U3 is the diode with a wrong label.
Cheers Don...Edited by donmck 2011-07-31
ksdesigns
Posted: 07:39am 30 Jul 2011
Don Yes that would be the diode i thought U3 was a strange label for a diode
donmck
Posted: 07:42am 30 Jul 2011
  ksdesigns said   Don Yes that would be the diode i thought U3 was a strange label for a diode
OK, I am following you, hate to think what you can achieve after breakfast Ken.
Cheers Don...
Keith @
Posted: 09:34am 30 Jul 2011
Ken
If you have removed the video and keyboard to free up 2 serial connections can one of these uarts be used with the "microVGA" module (see www.microvga.com) to reinstate these items if needed?
I take it that you haven't done any serial/uart coding as yet?
I'm trying to pick up where Nick left off with the colour video and the space invaders.
Keith
sparkey
Posted: 01:26pm 30 Jul 2011
i am amaized finally a maxi that can hold its own ...My maxi`s that i have
acquired:
:altronics ...
were from dontronics and they are ::
the sm1 from tctec
:and the embedded verision also by "tctec...
:and the "sm1 " has the capable ability for "rtc"...:
:: if you want the maxi to be a "stand alone unit "as to what it is intened to be then loading a new firm via the usb or a sd-card either way should be a good thing not having to plug into the pc :other than down loading the hex file onto the card ...:in my honest oppionn this is the way the trend is going :::
i am running the embeded maxi using it to switch between my video suvelaiance cameras its all fitted into the case of my crt on the side panels i had to cut a slot into the case to allow up to five "r-c-a" inputs that is a possability...
what i did to the preamp is in one.. of my earlier posts ...but if you read it yo may find complications for obvuious reasons that the i/o pins need to be held to ground..i used a "bc-549 "" in series to the "bc-640" so that te transistor needed more than ..point 6 volts to switch on an so on..... but basicly disconnecting the preamp from the switched input and appling five volts to the switching cct and ..presto 5 switched inputs ...:
regareds sparkey
:its All About Current
