Local Time 01:28 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MS DOS 30th Birthday
James_From_Canb
Posted: 12:14am 30 Jul 2011
Those with long memories might get a kick out of this interview with Bill Gates.
300MB drive prices getting down to only $10K to $15K, and being enough for 20 people? Wow.
I was hoping to find a quote about "no-one ever needing more that 1MB of available memory" but maybe that's just a myth.
It makes me wonder what could a development team of 20 could have done with a 32 bit Maximite over a year.
James
sparkey
Posted: 12:26am 30 Jul 2011
yuor a funny man... oh i have read hard drive....Edited by sparkey 2011-07-31
rhamer
Posted: 05:39am 30 Jul 2011
The real kicker here is that Microsoft didn't even write the first DOS that they sold.
Bill negotiated for exclusive rights to an existing product and renamed it.
If the original author had only kept a .01% interest in it he would have been a very rich man.....
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
sparkey
Posted: 06:38am 30 Jul 2011
geeze do you know my old bosses from 1983 or what///greg /phil /rod
donmck
Posted: 06:43am 30 Jul 2011
Bill Gates 1981:
[code]
I don't read about the TRS-80 any more because it does seem like a long time ago and
in comparison it would be pretty easy to make fun of it, but the year or two after we
did that project every time we would see somebody disassembling the BASIC or figuring
out some little trick we thought it was really exciting.
It's the combination. Software is a great combination between artistry and
engineering. When you finally get done and get to appreciate what you have done it is
like a part of yourself that you've put together. I think a lot of the people here
feel that way.
[/code]
Cheers Don...
https://www.dontronics.com
aargee
Posted: 07:10am 30 Jul 2011
In the very early eighties, I clearly (?) remember buying the Microsoft TRS80 (dis-)assembler, on tape, from Dick Smith Buranda. It was a bit over my head at the time, but I wish I'd kept the tape!
donmck
Posted: 07:16am 30 Jul 2011
  aargee said   In the very early eighties, I clearly (?) remember buying the Microsoft TRS80 (dis-)assembler, on tape, from Dick Smith Buranda. It was a bit over my head at the time, but I wish I'd kept the tape!
If I recall, the tape was 13K long, and took 8 minutes to load.
Cheers Don...
sparkey
Posted: 08:00am 30 Jul 2011
geeze looks like i will have to get another evb board to keep up with the mods ...chheers`s don
sparkey
Posted: 08:03am 30 Jul 2011
geeze i rember the days when a 20 meg "mfm" cost 5 grand.....
Posted: 11:08am 30 Jul 2011
My first "PC" was a AT with a 20meg MFM drive. CGA graphics too, it was a weapon! Funny thing is, I think it was faster than the computer I have today
James_From_Canb
Posted: 11:43am 30 Jul 2011
  Gizmo said   My first "PC" was a AT with a 20meg MFM drive. CGA graphics too, it was a weapon! Funny thing is, I think it was faster than the computer I have today
Now THAT made me laugh.
sparkey
Posted: 12:35pm 30 Jul 2011
ok fine ""my first pc was a 10Mhz turbo board ..8 bit machine..
:rtc card"
: multi i/o card
: twin floppys ds/dd/5 and 1 quarter inch
:actully had a :cga card ::
:that only ran monochrome..i have an origanal copy of "smart work ..and the manual very useless these days though
sparkey
Posted: 01:43pm 30 Jul 2011
you would be suprized at my amd 133 running at 200 Mhz and a peltier sitting on top of it ....:
:here is a good one for you i fired up one of old (P-1) mother boards "vx" chipset then once i had the flash program running i pulled out the "vx" eprom ..then plugged in my 486 eprom and flased the chip ...beat that if yu can..
there used to be a test practice site in the states i pulled up 20 a++ hard whare exames got a score of 399 out of 400 up set me so i sat one more test comeing out of it 419 out of 420...beat that ....Edited by sparkey 2011-07-31
James_From_Canb
Posted: 09:26pm 30 Jul 2011
  sparkey said   ok fine ""my first pc was a 10Mhz turbo board ..8 bit machine..
:rtc card"
: multi i/o card
That would have been the high-spec monochrome Hercules video card. Very nice, but there wasn't nearly as much support for games.
grub
Posted: 10:32pm 30 Jul 2011
The first computer I ever used was to program cnc machines. You had to boot it by manually changing toggle switches and the i/o was an electric typewriter. It could operate on assembly, basic, FORTRAN and Cobol. Storage was a paper ribbon that had holes punched in it. Even then you could get "girlie" pictures made from ascii characters. That was in 1978.
haiqu
Posted: 10:33pm 30 Jul 2011
:rtc card"
: multi i/o card
There were two monochrome standards: the original MGA and Herc, which was a 3rd party option. Could have been either.
My first personal machine was a Sirius I with the optional 10Mb HDD, which cost me $16k (plus HP charges) and lasted 9 years. This wasn't my first experience with computers however, since I was a computer service manager by that stage (1982) and repairing 28 different brands.
I later co-owned a lasercutting business, using it to generate CNC tapes via an ancient teletype with a CAD program self-written in compiled BASIC. By the end I had designed an upgrade to put 1Mb on the mobo and had an IBM PC emulator that could run Fidonet client software and dial into BBSes with a homebrew 300 (later modified to 1200) baud modem. I also made a plug-in that allowed me to record speech via the onboard PWM input and play it back through the speaker.
Rob
haiqu
Posted: 10:36pm 30 Jul 2011
  grub said   The first computer I ever used was to program cnc machines. You had to boot it by manually changing toggle switches and the i/o was an electric typewriter. It could operate on assembly, basic, FORTRAN and Cobol. Storage was a paper ribbon that had holes punched in it. Even then you could get "girlie" pictures made from ascii characters. That was in 1978.
Hah!! Remember the stainless steel girlie profiles you used to see stuck to the side of Kenworths? I had a tape that could lasercut those.
Rob
RossW
Posted: 01:40am 31 Jul 2011
There were a good deal more than that, actually, although they were probably the two best known.
I used to have a Wyse 700? (I think 1280x800 pixels), which was excellent for DTP work and schematics, there were a number of other fancier very high resolution boards too, but I couldn't afford them :(
Posted: 02:05am 31 Jul 2011
My first computer was a VIC20, then the all mighty Microbee. Then I discovered cars and girls, and didn't touch a computer after hours for a few years, though I still had to develope applications for the XT's at work. Back then Telecom ( Telstra now) trained its technical apprentices in BASIC programming, so we spend a lot of time developing databases and stuff. A few years later I bought the AT(286) 2nd hand and played around with DOS apps and games. But the biggest single event I can remember in my computer life was when I was visiting my brother in Brisbane, and he took me to his work place in the cella of some government office.
"Look at this, its a new game" he said, and fired up the shareware copy of Doom. I still remember the dimly lit room, the day, the first impression clearly. Within weeks I had a 486 with 4megs of ram, just so I could play Doom. And I must have spent weeks playing it.
I still play a lot of video games, Halflife, Portal, Minecraft etc. I even was pretty good at it once. There was a computer gamers group in Mackay many years ago, so I went along to see what it was about. I was mid 30's, and everyone else was early 20's, and looked at me like I was a grandad. We fired up a relatively new game called Quake2, one of my favourites at the time. Deathmatch, where you kill or be killed, and the highest kills ( or Frags ) makes you the winner. In the game was myself and about 6 other people, plus a few "bots", artificial players that are very tought to kill, never miss, and make the game a lot harder to survive in. First to 50 frags wins. After 10 minutes the game finished with yours truley in number one position, followed by the bots, and then the other people coming last. I quietly packed up my PC and went home, and for weeks I heard stories about the old man who came in and kicked their arses in Quake2 and then left, and no one knew his name.
I miss the deathmatch games, lots of fun.
vasi
Posted: 03:12am 31 Jul 2011
I liked both Quake2 and Halflife. But Halflife allowed me to play more without making me to vomit (I wear glasses) and staying for hours sick in bed. It had a better 3D engine. There, I tried hard to save every scientist and to keep alive all guardians found on corridors...
I kept alive my DOS for Turbo Pascal 7, DJGPP, a few FoxPro 2 applications, Dune and Dune 2, UFO-Unknown Enemy games. But in time, I lost the motivation. I intended to use it for TurboCNC and CNCPro but now I try to move to USB ports,,,
So now, just Linux and Windows and for a short period, Mac OS X 10.4. Some times I use DOSBox for Clipper 5 and Borland C++ 3.1
Elvish name: Mablung Miriel
Beyound Arduino Lang
