Local Time 01:28 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Do we have lift off?
donmck
Posted: 08:53am 22 Jul 2011
We are on the pad, and waiting for the main engine to ignite!
OK, this is a mock up of a Maximite EV board with a DonDuino Cross mounted on top, and an Ebay $16 LCD (including postage) Arduino shield sitting on top.
Mick is just writing the software to make it tick as we speak.
and some more:
And a pair:
I'll let you know when we get them going.
Cheers Don...
https://www.dontronics.com
donmck
Posted: 11:17am 22 Jul 2011
As Mick said, "Who's a pretty boy"?
Here is is shown sitting on top of a case with the cable entry from the rear of the DonDuino Cross.
And the code.
[code]
10 GOSUB 11000 ' Initialise the LCD
20 LCD_line1$ = " *Dontronics* "
30 LCD_line2$ = " DonDuino Cross "
40 GOSUB 12000 ' send to the LCD
50 END
60 '
70 '
80 '
10000 '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''
10010 ' LCD driver for standard 16 x 2 LCDs
10020 ' Originally by Geoff Graham, March 2011, for Arduino by Mick Gulovsen July 2011
10030 '
10040 ' For example: futurlec.com LCD16X2
10050 ' altronics.com.au Z7001
10060 ' jaycar.com.au QP5512
10070 '
10080 ' To use:
10090 ' - execute GOSUB 11000 to initialise display
10100 ' - then load the text strings into the
10110 ' variablesLCD_line1$ and LCD_line2$
10120 ' - execute GOSUB 12000 to display the text
10130 '
10140 ' See the file lcd.pdf for the schematic.
10150 ' Maximite pin 19 is RS, pin 20 is EN
10160 ' pins 15 to 18 are D4 to D7. R/W is grounded
10180 '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''
10190 '
10200 '
11000 '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''
11010 ' Initialise the LCD
11020 '
11030 FOR i=15 TO 20: SETPIN i,8 : NEXT i
11040 _LCD_byte = &B0011 : GOSUB 13090 : PAUSE 5 ' reset
11050 _LCD_byte = &B0011 : GOSUB 13090 : PAUSE 5 ' reset
11060 _LCD_byte = &B0011 : GOSUB 13090 : PAUSE 5 ' reset
11070 _LCD_byte = &B0010 : GOSUB 13090 : PAUSE 2 ' 4 bit mode
11080 _LCD_byte = &B00101100 : GOSUB 13000 ' 4 bit, 2 lines
11090 _LCD_byte = &B00001100 : GOSUB 13000 ' display on, no cursor
11100 _LCD_byte = &B00000110 : GOSUB 13000 ' increment on write
11110 _LCD_byte = &B00000001 : GOSUB 13000 ' clear display
11120 RETURN
11130 '
11140 '
12000 ' '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''
12010 ' send the two lines to the LCD
12020 ' the text is in LCD_Line1$ and LCD_Line2$
12030 '
12040 _LCD_byte = &H80 : GOSUB 13000 ' select the 1st line
12050 FOR _LCD = 1 TO 16
12060 _LCD_byte = ASC(MID$(LCD_Line1$, _LCD, 1))
12070 PIN(19) = 1 : GOSUB 13000 ' send the character
12080 NEXT _LCD
12090 _LCD_byte = &B11000000 : GOSUB 13000 ' select the 2nd line
12100 FOR _LCD = 1 TO 16
12110 _LCD_byte = ASC(MID$(LCD_Line2$, _LCD, 1))
12120 PIN(19) = 1 : GOSUB 13000 ' send the character
12130 NEXT _LCD
12140 RETURN
12150 '
12160 '
13000 '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''
13010 ' Send a byte to the LCD
13020 ' the data to be sent is in _LCD_byte
13030 '
13040 PIN(15) = _LCD_byte AND &B00010000 ' output the 1st 4 bits
13050 PIN(16) = _LCD_byte AND &B00100000
13060 PIN(17) = _LCD_byte AND &B01000000
13070 PIN(18) = _LCD_byte AND &B10000000
13080 PIN(20) = 1 : pause 1:PIN(20) = 0 : pause 1 ' tell lcd to accept data
13090 ' Entry point to send just 4 bits to the LCD
13100 PIN(15) = _LCD_byte AND &B00000001 ' output the 2nd 4 bits
13110 PIN(16) = _LCD_byte AND &B00000010
13120 PIN(17) = _LCD_byte AND &B00000100
13130 PIN(18) = _LCD_byte AND &B00001000
13140 PIN(20) = 1 : pause 1: PIN(20) = 0 : pause 1: PIN(19) = 0 : pause 5 ' tell lcd to accept data
13150 RETURN
[/code]
We have a Maximite, running via a DonDuino Cross, to an eBay Arduino shield.
Mick is now working on the switches. He has most of them figured out.
Cheers Don...Edited by donmck 2011-07-24
donmck
Posted: 03:41pm 22 Jul 2011
Mick just found the schematic of the LCD:
http://www.nuelectronics.com/estore/index.php?main_page=proj ect_lcd
Cheers Don...
VK6MRG
Posted: 03:55pm 22 Jul 2011
WOW, looks good.
sparkey
Posted: 07:31pm 22 Jul 2011
hey don micro sd cards fom office works 12 bucks oh think they said 2gig regards sparkey they have largerEdited by sparkey 2011-07-24
sparkey
Posted: 08:54pm 22 Jul 2011
a`hh litle confused on what this is ///i gather "in old term`s"it is an expansion buss....or am i totally wrong...or is this what we might call the daisy chain .....
donmck
Posted: 09:49pm 22 Jul 2011
  sparkey said   a`hh litle confused on what this is ///i gather "in old term`s"it is an expansion buss....or am i totally wrong...or is this what we might call the daisy chain .....
Hi Sparkey, I think we have been talking in depth about Arduino shields for about 3 to 4 weeks on this forum.
Have a read of this:
http://www.themaximitecomputer.com/the-donduino-cross/
and this:
http://www.dontronics-shop.com/the-donduino-cross.html
and the links from here:
http://www.arduino.cc/en/Main/ArduinoShields
and here:
http://shieldlist.org/
that will give you a little idea of the potential of the shield system, and how it can complement the Maximite.
VK6MRG
Posted: 09:59am 23 Jul 2011
Don, do you have an enclosure that would suit the Maximite EV with an expansion board on top?
donmck
Posted: 03:34pm 23 Jul 2011
  VK6MRG said   Don, do you have an enclosure that would suit the Maximite EV with an expansion board on top?
Sorry Matthew, I don't.
This is much like any Arduino shield now. Most of them are home grown stacks and you would need to sort out a jiffy box to house it.
Cheers Don...
jman
Posted: 07:20am 28 Jul 2011
Hi Don
Recieved the DonDuino boards today as expected they look great
Will put one together and post results
I have a shield comming so I can test
donmck
Posted: 07:26am 28 Jul 2011
  jman said   Hi Don
Great, thanks for the feed back John,
I figure this should make the add on Arduino shields dead easy for the Maximite.
Cheers Don...
