Local Time 00:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Available, a small herd of Maximites.
donmck
Posted: 07:31am 11 Jul 2011
As many users on the Forum will know, I have been able to get a few of the new production boards out to you.
This is what I have left from the first new batch of 8 of each of the MM-EV, and MM-SM1:
http://www.dontronics-shop.com/the-maximite-computer.html
I know they won't last long, and I wanted to give The Back Shed Maxiteer members first crack at it.
Orders only through the shopping cart please. To do to it manually, is a bit of a nightmare.
Shipping Wednesday or Thursday. (Unless a package gets lost.)
Then we wait another 3 or 4 weeks for the first reasonable volume batch.
Cheers Don...
https://www.dontronics.com
sparkey
Posted: 01:16am 12 Jul 2011
could you put one of them aside for me please as i want one to run my cameras and the one i have atm i have almost got it ready to run my inverter and such ...
regards sparkyi will have the money next week so if you still have a smd one with i/o`s i would be most pleased we can meet over a cup of coffe if you would like...
donmck
Posted: 01:26am 12 Jul 2011
  sparkey said   could you put one of them aside for me please as i want one to run my cameras and the one i have atm i have almost got it ready to run my inverter and such ...
Brian, if you can send me an email instead of going via the Forum, it would be appreciated.
support2011 AT dontronics.com
Cheers Don...
donmck
Posted: 01:54am 12 Jul 2011
All SM1s now gone, have a few EVs left:
http://www.dontronics-shop.com/maximite-ev-embedded-version. .html
Cheers Don...
donmck
Posted: 05:17am 13 Jul 2011
Cheers Don...
I can't keep the SM1s in stock, and people are now asking about the EV version as a replacement, and if it can be used as a full board version, so I have added this to the page:
This version has no keyboard connector, and no VGA connector. It is designed as an end product for applications developed on the Maximite Computer.
This EV board has the same Firmware as the full SM1 board version. It is only missing the keyboard and VGA connectors. If you look at the circuit, all the components are on the board, you just have to connect to the pads provided for the keyboard and VGA.
Schematic:
http://www.themaximitecomputer.com/max/Programs/
Then Select Hardware, then tctec
Hope this helps explain the situation.
Cheers Don...
Edited by donmck 2011-07-14
sparkey
Posted: 02:20pm 14 Jul 2011
dear dom could you post a direct url so i down load all the nesscary data on this new board also it works but i need to know what the jumpers r setting..regards sparky and thank you...
donmck
Posted: 04:55pm 14 Jul 2011
  sparkey said   dear dom could you post a direct url so i down load all the nesscary data on this new board also it works but i need to know what the jumpers r setting..regards sparky and thank you...
Hi Sparkey.
The product page is at:
http://www.dontronics-shop.com/maximite-sm1.html
And all the information is linked from there.
However to check the schematic and jumper settings, this text and links are given on that product page:
Schematics and all other relevant files are available from:
http://www.themaximitecomputer.com/max/Programs/Hardware/tct ech/
However a much nicer entry to this directory listing is from:
Please let me know if you are having problem with this, and we will sort it out.
And if you end up making a list of what all of these jumpers do, then I'll add the list to my product page to assist other users.
As you know, you saw the product for the first time, about two hours after I did.
Like any new product, the on line data that goes with it, always needs to be fine tuned, to make it easier for the customer.
This is day one of the product.
Cheers Don...Edited by donmck 2011-07-16
