Forum Index : Microcontroller and PC projects : ERROR 500 Problem with uploading files
Ray B
Posted: 03:28am 03 Jul 2011
When I try uploading files I get thr following error. Any ideas how to overcome
HTTP Error 500
Oops! Looks like the page you wanted has a error.
A email has been sent to the site owner. Please click your browsers BACK button, or go to the home page.
http://www.thebackshed.com
error '80020009'
Exception occurred.
/errormsg/500-100.asp, line 118
RayB from Perth WA
Posted: 03:38am 03 Jul 2011
What type of file are you uploading, and how big is it? Once I know I can do some tests.
Ray B
Posted: 03:50am 03 Jul 2011
Using this POST REPLY box I go to the list button on the right (upload),
follow the instructions on the popup box and browes to the required file - noting max size restrictions "Files must be of the type, zip, rar, pdf, and have a maximum file size of 2000KB".
Several times tried uploading jpgs & PDF files and always get this error.
RayB from Perth WA
Posted: 04:07am 03 Jul 2011
OK, we'll work it out. Can you try uploading a image. A JPG file. If you get the error, try resizing the file down to something like 600 pixels wide and try again. Let me know what happens.
Posted: 04:08am 03 Jul 2011
Hang on, dont upload a image with the file upload button, use the image upload button, to its left.
Posted: 04:11am 03 Jul 2011
Hold on, think I've found the problem.
Posted: 04:17am 03 Jul 2011
OK think its fixed, there was a bug in the code that uploads files.
Use the File Upload button to upload PDF's or Zips. Images can only be uploaded with the Image Upload button.
Thanks for pointing out the problem.
Ray B
Posted: 05:10am 03 Jul 2011
2nd buttom from right below OK to upload a JPG as follows
but still can't find way to upload PDFs - where is the File Upload button ?
RayB from Perth WA
Posted: 05:11am 03 Jul 2011
Yeah, the file upload button, next to the image upload button.
Ray B
Posted: 05:21am 03 Jul 2011
So the PDF file button is right hand button & now works as attached
Looks like it is all fixed, Thanks guys
2011-07-03_151934_BS1APPS.PDF
RayB from Perth WA
